nitro daves wet plate kit dyno numbers
Old 11-04-2008, 06:57 AM
dawiz's Avatar
Default nitro daves wet plate kit dyno numbers
150 shot with .38 fuel jett is the first graph. as you can see it went to 10.x's. a little rich so we put in the .35 fuel jet and it ended up at 11.2x's so we felt it was perfect right there. 110 leaded in the dedicated and 93 in the tank.
car made 440 on motor.
ported ls6 heads,england green whiplash cam,lts modded ti's,ported 78mm fast.
Old 11-04-2008, 08:19 AM
Beer99C5's Avatar
Sweet! Pics of the setup?
Jim
Old 11-04-2008, 09:26 AM
BOTTLEFEDLS1Z's Avatar
You should of picked up at least 150RWHP. Car should be making more power IMO...
Old 11-04-2008, 10:33 AM
dawiz's Avatar
but it didnt. is everyone else picking up 150rwhp on the 150 jets for daves kits?
Old 11-04-2008, 10:47 AM
Originally Posted by dawiz
but it didnt. is everyone else picking up 15rwhp on the 150 jets for daves kits?
BUT IT SHOULD!!!!
If your not worried about it, then who cares.
I picked up 167 RWHP on the 150 pills. Same set-up as you. 110 in a dedicated and 93 in the tank. Thats with a A/F of 11.0 and 22* of timing......
Old 11-04-2008, 11:05 AM
dawiz's Avatar
what size n2o jet?
Old 11-04-2008, 11:12 AM
Beer99C5's Avatar
When I was stock here was mine gain
300 RWHP was baseline, this was a 62/36 jetting I found Stock the jetting was rich, and went 2 sizes smaller on the fuel.
Old 11-04-2008, 11:13 AM
1969mach1's Avatar
Originally Posted by BOTTLEFEDLS1Z
BUT IT SHOULD!!!!
Are you running the same cam, and transmission??? You do not always pick up what the nitrous company states; it's just an estimate of power.
Old 11-04-2008, 12:00 PM
LS1 SPEED's Avatar
graph looks good
HP doesn't always come out the same, so I would not be concerned
another note is he may have not pulled it to the same RPM as he did on motor just a guess by only seeing 6400 rpm
Old 11-04-2008, 05:15 PM
dawiz's Avatar
im trying to get the shop to send me a lay over of the motor vs. spray so we can see the under the curve power gain. its impressive!
Old 11-04-2008, 05:40 PM
Loudmouth LS1's Avatar
Scott, how much total timing on the 150 and what plugs?
Old 11-04-2008, 06:24 PM
bad6as's Avatar
any one else think 11.2 is rich?
Old 11-04-2008, 07:48 PM
dawiz's Avatar
better safe than sorry
Old 11-04-2008, 07:52 PM
dawiz's Avatar
tr6's not 100% sure on the timing. i was tired and had alot on my mind.
Old 11-04-2008, 07:58 PM
waterbug1999's Avatar
I bet you have the 52 n20 jet in.. The 52/35 (100 shot) should be a tad rich. Still, Nice power.
Old 11-04-2008, 08:24 PM
bad6as's Avatar
hum, im at 12.0 on my 150
Old 11-04-2008, 08:54 PM
I ran my 10.71 at 12.8-13.0 AF.... Was the last race of the year, I had TR7's and 100 octane, so I figured I would be fine for a run.
Old 11-05-2008, 05:21 AM
dawiz's Avatar
nah, its a 62. i checked,checked and rechecked before installing it.
Old 11-05-2008, 06:18 AM
2001z's Avatar
Nice graph. I need to get me his plate setup!
Old 11-05-2008, 07:07 AM
slow trap's Avatar
what was the bottle pressure ? if it was 950 or so i would put the 38 back in and heat it up to 1050-1100. a/f should be somewhere in the mid 11x range and hp will pick up, that is if you are wanting more.i run mine at 24* on spray (dyno only so far) with i think 110 in the stand alone.
anyways your car will be strong on the jug so congrats.
Quick Reply: nitro daves wet plate kit dyno numbers
