General Maintenance & Repairs - Oil Change Light
View Full Version : Oil Change Light
GreenBlood
11-04-2008, 09:58 AM
Ok, so sometimes after I change my oil, my car will be fine for a few days, and then randomly, the orange Oil Change light comes on when I first start the car. After a couple of minutes it goes away. Any reason why it does this? Its only been 2 weeks and 800 miles since I changed the oil with German Castrol 0w-30 and a K&N oil filter...Should I be worried about the light?
keliente
11-04-2008, 10:15 AM
You need to reset the light manually, it does not know when you changed the oil. Turn the key on and hold the trip counter reset button for 12 seconds or so, that will reset the light.
GreenBlood
11-04-2008, 11:56 AM
ok, thanks
TAtoad
11-06-2008, 12:03 PM
the gas pedal method worked on my car to erase the light. also on a buddys z28
ghardester
11-06-2008, 08:46 PM
It is also not a measure of how dirty your oil is or how many miles have passed between changes. It is a simple count of start cycles that attempts to predict when you should change your oil.
ae13291
11-06-2008, 08:52 PM
i only seen my oil change light once. i dont usually reset the light after an oil change, but mine has not come on yet? is it broken
johnLs1camaro
11-06-2008, 08:57 PM
well before i have never seen mine come on, and i drove the car for probably 10000 miles and then i was pulling the starter and broke that damn sensor, and now it will just come on at random times...so idk..
