Quick U-joint Question
Old 11-04-2008, 02:18 PM
Z28M6TT's Avatar
Default Quick U-joint Question
what are the best u-joints to use with a stock rear and stock d/s?
the reason i ask is because unfortunately i noticed that one of my exhaust bandclamps had turned and cut a groove into my d/s i got a used stocker from ebay and im waiting for it to come in because i dont have the $400 for a 3.5". my car is pretty much stock except for an LS7 clutch and im putting kooks lt's in so i figure the stock d/s should be fine for now. i just want to to replace the u-joints since it is used and i hear u can get stronger ones from napa.
Thanks in advance.
Old 11-04-2008, 11:09 PM
CW00BlackTA's Avatar
Thanks in advance.
I like the Spicer no-maintenance joints. NAPA doesn't carry them. Really, whatever you get at NAPA is going to work fine though.
Old 11-05-2008, 03:04 PM
Z28M6TT's Avatar
my main problem is i cant find what kind of joints your supposed to use with a stock rear. they say to use 1350 if you have a 12 bolt, but my rear is a stock 10 bolt...
