Stroker Motor 382.....422 numbers?
Old 09-18-2003, 12:21 AM
BBADWS6's Avatar
Default Stroker Motor 382.....422 numbers?
I was just curious as to what kind of HP you guys were getting out of your motors/setups. In no way am I in the situation to buy or build a motor, but lets see what you got
Old 09-18-2003, 12:49 AM
2001CamaroGuy's Avatar
Default Re: Stroker Motor 382.....422 numbers?
It seems to ranges from 475 - 550 rwhp depending on CI and how wild the cam is.....
Old 09-18-2003, 12:50 PM
BBADWS6's Avatar
Is 382 as big as you can go with just stroke, one a LS1 block?
Old 09-18-2003, 12:53 PM
93Polo's Avatar
You can go to a 395 with a 4.125 stroke. #82 is a 4.00 stroke
Old 09-18-2003, 01:02 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
ARE 422ci
4.075 stroke (4.000 offset ground)
4.060 bore (iron block)
S1 244/244/112
LS6 stage III heads
475rwhp/ 505rwtq
On Speed Inc. dyno, on 28" slicks, converter locked, thru Moser 9" with 4.11's... and with dual exhaust and H pipe.
Old 09-18-2003, 02:30 PM
TTtop's Avatar
MTI 383ci
4.000 stroke (lunati crank/rods/wiseco pistons)
3.905 bore (LS6 alum block)
R1 cam: 232/236/.575/.578/114
MTI LS6 stage II heads
458rwhp/448rwtq
On MTI dyno, thru Moser 12-bolt with 4.10s, on 245/50/16 Nitto DRs, and with cutout open.
See sig. for rest of setup.
I currently have an FLP 2.5" y-pipe and the LS1edit tuning is still not complete (90%).
Will get a 3" custom y-pipe and wide-band tuning at MTI very soon and expect to make 470+rwhp/460+rwtq with those additions!
This is a very streetable engine that idles very smooth once it has warmed up. Also got 29mpg on a 350 mile trip towards Dallas a month ago, averaging 80-85 mph in 6th gear.
Randy
Old 09-18-2003, 11:04 PM
BBADWS6's Avatar
John, those are awesome numbers , but i have to say Randy your set up is very impressive also. You are only 15HP behind a 422 stroker. Thanks for sharing the info guys.
Anyone Else?
