ceramic coating or just header wrap??
Old 11-04-2008, 10:43 PM
vogun16's Avatar
Default ceramic coating or just header wrap??
i just bought the PTK style turbo kit off ebay and beofore i just tearing down and installing i was wondering if i should just header wrap the headers and all the exhaust or should i spray it with the ceramic coating stuff they sell at the parts store, then wrap it?? i know keeping more heat in will help the turbo spool faster.. but am i just wasting my time and money or will it acctually make a differance??
Old 11-05-2008, 12:19 AM
DeltaT's Avatar
The wrap will help but ceramic coating does not like having wrap over it.
Wrapped headers don't like getting wet very much either - it will help rust out much faster. If you don't drive in the rain, then it's cool.
If you do, then pay the extra money to get the parts ceramic coated the right way - at a plating or coating shop. The silver Ceramicoat is good to about 1300F and the grey and blacks are both good to about 1800F, if properly applied and baked.
Jim
Old 11-05-2008, 12:28 AM
Grr
Grr's Avatar
true, get some good ceramic coating then wrap, i could put my hand on my downpipe right after the turbo, no rust, no nothing. best way hands down.
Old 11-05-2008, 06:17 AM
Photochop's Avatar
Why do you say this? Will it not hold as well with wrap over it? I had mine crossovers professionally sandblasted and recoated, then applied wrap over them. Was this a bad call? I thought the idea here was to keep the heat in the pipes...
Old 11-05-2008, 03:34 PM
no title here
skyhighsami's Avatar
I think the point was that when you coat it and wrap it the pipes can't breathe and dry out if they get wet. If I follow the logic, though I would think that the pipes would get hot and vaoprize the water and moisture. That is my logic, I am sure it is wrong but I too am curious because I am planning on at the least coating my stuff
Old 11-05-2008, 08:26 PM
vogun16's Avatar
all my exhaust pieces are stainless so im not to worried about them rusting, ill make a few phone calls tomorrow, does anyone know of any good coating places in the MA or NH area??
Old 11-05-2008, 09:11 PM
94m6Z28's Avatar
im going to get it all coated and wrap the super hot areas. i figur ill have it apart again befor it has a chance to rust and the heat it throws will make short work of any water in there
Old 11-06-2008, 06:53 AM
orlandofast1's Avatar
Skyhigh is right about the wrap holding in the moisture. I went with a ceramic place in town www.performancekote.com and have been very happy. They also gave me a 3 year warranty. I also immediately noticed cooler under hood temps. My vote is to get them coated.
Old 11-06-2008, 07:56 AM
vogun16's Avatar
but would you get them wrapped too? or just coated?
Old 11-06-2008, 08:01 AM
Big Bird WS6's Avatar
place i am going to is QC coatings.
Old 11-06-2008, 08:31 AM
I just went with the coating and would suggest the same.
Old 11-10-2008, 11:48 PM
DeltaT's Avatar
Even when I simply used a single wrap around 1 header pipe that was coated, the ceramic flaked off and the pipe rusted within about 6 months of dry driving. Ceramic coating like to be exposed to air. Wrap overheats it locally and it fails, then you get rust. Originally tried wrapping my collectors for 'double' heat retention. Rust under wrap while the rest of the headers looked pretty good for the next 4 years.
Jim
Old 11-11-2008, 03:33 AM
96BIGBODY's Avatar
About to buy that same kit. I'm just gonna wrap it.
Old 11-11-2008, 04:36 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1557
This coating helps to prevent moisture from getting into the header wrap. Bob
Old 12-13-2008, 09:21 PM
mike13's Avatar
So what works better for keeping heat in the pipes ceramic coating or wrapping the pipes? This would be for a rear mount turbo set up. I'm looking to do the y pipe and mid pipe.
Old 12-13-2008, 11:58 PM
DeltaT's Avatar
Wrap with hi-temp ceramic batting underneath. You want it firm but not so tight it compresses all the air out of the batting. I got mine from Longacre racing.
Jim
Quick Reply: ceramic coating or just header wrap??
