How to get SS wheels to fit flush with the rear?
Old 11-05-2008, 12:27 AM
Vicinity's Avatar
Default How to get SS wheels to fit flush with the rear?
Since SS wheels are only 9 inches wide, is there anything that can make the rears fit flush with the top of the rear, sort of like this:
Or do I need 10.5's?
Old 11-05-2008, 12:38 AM
pumpkinman's Avatar
a spacer will do
Old 11-05-2008, 12:41 AM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
A 1" wheel adapter will do that...you may even want 1-1/2". Depends...if u have a 275 tire....1" will even it out. I have 1" wheel adapters on my 285 tire in sig.
Old 11-05-2008, 12:51 AM
Vicinity's Avatar
So a 1 inch spacer is possible without replacing the studs?
Old 11-05-2008, 03:03 AM
blwn_00gt's Avatar
the spacer has its on studs..
Old 11-05-2008, 10:04 AM
ls2 bait's Avatar
to do it right you will need an 11" rim. but a 1.5" spacer will get it out there.
Old 11-05-2008, 10:15 AM
99Bluz28's Avatar
Lightbulb
1" hub spacer/adapter Is what you need; something like Eibach or H&R 1" hub spacers.
Old 11-05-2008, 12:17 PM
OutKlast's Avatar
As others mentioned a spacer will do.
Quick Reply: How to get SS wheels to fit flush with the rear?
