Another fuel pump install ? (with pics)
Restricted User
I'm having trouble installing my new fuel pump. I've got the assembly out of the tank and have the pump installed with everything but the venturi tube. In the pictures you can see the long brown tube. In stock pump, there's a brass fitting that the tube slides over. On the new Wahlbro pump, there's no fitting, just a dimple. For those that have done this before: do you just push the venturi tube into that hole? I hope the pics help, thank you.
