Schrader valve install
Old 11-05-2008, 12:16 PM
ARCTICWHITE98Z28's Avatar
Default Schrader valve install
I removed my schrader valve a couple of years ago to install a wet nitrous kit. I have a 98 Z28. I removed it from the Driver's side fuel rail.
I recently sold the nitrous kit and bought a Schrader valve core from GM. What tool do I use to install this? Thanks.
Old 11-05-2008, 12:21 PM
tim99ws6's Avatar
There are valve install tools at any local auto parts store. Then again, i had to stick one in this weekend for a buddy of mine, and didn't have my tool. I just used a really skinny pair of needle nose pliers and threaded it in that way.
Old 11-06-2008, 04:48 PM
9000th01ss's Avatar
Go to a bike shop or look in the tire accesories, valve stems, etc, section of an auto parts store. Or look on your bicycle. A lot of valve stem caps have the schrader install tool right on it.
Old 11-07-2008, 10:37 AM
1sick'98WS6's Avatar
Im wondering about this, does that shrader valve have to be a gm one, arent these pretty universal and wouldnt any shrader valve work from a kit
Old 11-07-2008, 11:07 AM
kyles2000z's Avatar
just go to a tire store and they prob have some laying around the shoo they would just give you
Old 11-07-2008, 04:03 PM
9000th01ss's Avatar
They are universal. One exception I know of is the one at the end of a compression gauge, they have weaker springs.
I've seen some with different rubber/plastic sealing materials also. Not sure if this would have an effect on exposure to fuel. But it shouldn't matter as long as you always keep a cap on it.
The cap is there to keep debris out of it and to protect it from leaking.
