Lightest "street" K member out there
Old 11-05-2008, 02:05 PM
Dragkid1917's Avatar
Default Lightest "street" K member out there
I always thought that BMR had the lightest K-member at 24.5 lbs, but when I read racecrafts website It says they have one for 20.2 lbs w/motor mounts included. Is this streetable or strictly for drag racing, because if so it would make it the lightest out there. Does anyone have any experience with this K member or any imput on weight?
Old 11-05-2008, 02:19 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, thats correct ours is 24.5lbs and holds up well for street use. Its constructed from 1 5/8" x .120 and 1 1/4" x 0.95 wall dom steel tubing.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-05-2008, 02:23 PM
TRZ Motorsports's Avatar
I'm running Racecraft's K-member on my 02' Camaro which is driven every day and driven to the track occasionally. It fit great and no problems w/ driving all over the place. Honestly though, we don't have any experience w/ anyone else's K-members besides theirs in the F-bodies.
Old 11-05-2008, 02:39 PM
BMR Tech's Avatar
If you have to bolt the factory cast iron mounts back onto the Racecraft unit it the weight is going to escalate pretty quick. Our K-member has integrated motor mounts so the factory stands are not needed.
If you have any other questions regarding our products please feel free to ask
Old 11-05-2008, 02:57 PM
ROCNDAV's Avatar
Lightest one that I know of was Profab's (no longer in business) but I'd only recommend that for an all out drag car and with Spohn's Solid mounts.
Old 11-05-2008, 03:28 PM
Yhe im still a little confused, im not sure if the racecraft one needs you to use your own mounts. It does however say 15 lbs with no mounts and 20 with them.... heres the website, let me know if u think it uses stock or integrated motormounts.
http://www.racecraft.com/proddetail....d=429300000000
Old 11-05-2008, 04:05 PM
ROCNDAV's Avatar
That looks like the old profab k member. It uses the OEM (or Spohn Solid) mounts. it DOES NOT have integrated mounts:
Old 11-05-2008, 04:08 PM
shdybrady1988's Avatar
how much does the stock one weight?
ROCNDAV's Avatar
Here are the spohn solid mounts:
http://www.spohn.net/shop/1998-2002-...or-Mounts.html
and in looking for that link, I see that they now have light weight motor mounts (5 lbs less that OEM):
http://www.spohn.net/shop/1998-2002-...ng-Stands.html
Old 11-05-2008, 04:14 PM
BIG_MIKE2005's Avatar
So can you not use the Spohn solid motor mounts with the BMR k-member?? If you want solids you need to run the Racecraft??
Just curious as I plan on a k-member & solid motor mounts within the next year.
Also on the Racecraft does it accept aftermarket as well as stock upper/lower a-arms?? I believe BMR does, but just not sure if you can use solid mounts on BMR.
Old 11-05-2008, 04:18 PM
BMR Tech2's Avatar
If your referring to the stock member, with motor stands they weigh 55.75 lbs, without stands 43.75 lbs.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-05-2008, 04:23 PM
Black02SLPSS's Avatar
If you want to run the spohn solid mounfs you will either have to use the spohn k member or others without integrated mounts like the bmr unit has.
Old 11-05-2008, 04:29 PM
ROCNDAV's Avatar
BMR does make K members without integrated motor mounts.
http://www.bmrfabrication.com/F-bodyChassis.htm
Old 11-05-2008, 04:41 PM
1FASTBIRD's Avatar
I went with the UMI one
Old 11-05-2008, 04:48 PM
zracer323's Avatar
Are you still running the stock motor mounts?
Old 11-05-2008, 04:49 PM
ROCNDAV's Avatar
I did too, but I had to sell it
Old 11-05-2008, 04:52 PM
1FASTBIRD's Avatar
Why??? Didn't like it
Old 11-05-2008, 04:56 PM
ROCNDAV's Avatar
No, money issues (see link on sig).
I loved it. I previously owned the profrab K member before and sold it to buy the UMI K member.
Old 11-05-2008, 05:03 PM
Looks like thats the one I'll probably be goin with then.
I checked UMI's site but didn't see a k-member without integrated motor mounts. So I guess you can't run their k-member with solid mounts.
Old 11-05-2008, 05:08 PM
1FASTBIRD's Avatar
Damn that suck's bro sorry to see that you have to sell some stuff..
Quick Reply: Lightest "street" K member out there
