What to lube suspension wise?
Old 11-05-2008, 07:06 PM
jaywalkersw's Avatar
Default What to lube suspension wise?
OK, I have a lot of squeaks coming from both the front and rear suspension when I go over large bumps (like speed bumps). I was told that this was fairly common and that if I greased the suspension it would help significantly.
What should I grease in the front and rear and how do I do it?..eg just use the hose on a grease gun and try to squirt it in or do I need to disconnect anything then grease and put it back together?
Old 11-05-2008, 08:51 PM
35th SS's Avatar
I use primalube from Lubemaster color red grease.using a cordless greasegun.no squeaks here.
Old 11-05-2008, 09:00 PM
ae13291's Avatar
i had a very annoying squeak over speed bumps. start off by spraying water on suspension parts individually see if the sound goes away. mine turned out to be the rear swaybar bushings
Old 11-05-2008, 10:26 PM
Ok, so far Ive been told to do the rear sway bar and LCA...is there a technique to doing these or is it squirt grease in them while its on a lift...or do I have to take these pieces off the car or loosen the joints before greasing?
Old 11-05-2008, 10:29 PM
ae13291's Avatar
i removed the sway bar bushings and greased them with valvoline semi sythetic grease
Old 11-05-2008, 10:53 PM
What all is involved in taking the bushing loose....Ive never done it. Do you just unbolt it, or do you have to jack up the differential to take pressure off?
Same question about the LCAs
Old 11-05-2008, 10:58 PM
jsteele90's Avatar
u can just unbolt it
Old 11-05-2008, 11:03 PM
Ok thanks...Im guessing the same for the LCAs?
Old 11-06-2008, 11:14 PM
You guys were right...just unbolted, cleaned, and greased them = no more embarrassing speed bumps...now if I could only get that piece of my cat that is stuck in my muffler out...
Anyways thanks so much for the help. The car doesn't sound like a thirty year old bed being jumped on by fat kids any more. I appreciate the help!
