tire size for 18/19 in. wheels
Old 11-06-2008, 04:38 PM
94 ss's Avatar
Default tire size for 18/19 in. wheels
get 18-8.5 and 19-10 in. wheels. what tire would you guys recommend? thinking of 245-40-18 for the 18's and 275-30-19 for the 19's this a good size? thanks in advance.
Old 11-07-2008, 04:03 PM
BandDirector Blk98ZM6's Avatar
The sidewall difference will look odd IMO if you go with those sizes...I'd go 255/35/18 front with the 275/30/19 rears.
Old 11-07-2008, 04:15 PM
michaelg589's Avatar
Originally Posted by BandDirector Blk98ZM6
The sidewall difference will look odd IMO if you got with those sizes...I'd go 255/35/18 front with the 275/30/19 rears.
I agree. I dont believe different diameter wheel belong on an f-body.
However, your tire sizes would almost be right. The 275-30-19 would be a little stretched out and the overall diameter is very slightly smaller than your front would be. I say change the rear size to 285-30-19 and it'd be just right.
Old 11-08-2008, 12:06 AM
99Bluz28's Avatar
Thumbs up
Front,245/40/18s .
Rear, 275/35/19s, 285/35/19s or 295/30/19s all have a side wall > a 245/40/18.
Old 11-08-2008, 05:26 AM
Originally Posted by 99Bluz28
Front,245/40/18s .
yes but the 275-35-19 and 285-35-19 would be way too tall of a tire.
Old 11-08-2008, 07:21 PM
99Bluz28's Avatar
Thumbs up
Their not really much taller than a 275/40/18, which I run as my rear tire size without any problems.
Are you referring to possible abs problems, because of the tire height variation from front and rear?
Myself, I have'nt had any problems with that.
Old 11-08-2008, 08:14 PM
the 275-35-19 would be an inch taller than stock. the 285-35 even more. I was referring to the ABS problems. What size front tire are you running. I was sure that if there was more than about a 3/4" difference in diameter it would start pissing off the TCS and ABS. I have 275 and 295-35-18s. My ABS seems very touchy and thats only a 1/2" difference.
Old 11-08-2008, 09:52 PM
245/40/18 = 25.72" overall diameter, sidewall height = 3.86"
255/35/18 = 25.03" overall diameter, sidewall height = 3.51"
275/30/19 - 25.5" overall diameter, sidewall height = 3.25"
There's only a 1/2" differnce in the 275/30/19 to the 255/35/18, so that won't throw the ABS off. The 245/40/18 has an extra 1/2" of sidewall height over the 275/30/19, it's also an overall larger in diameter tire than the 275/30/19, and if you see pics of cars that run 245/40/18's front with 275/30/19's rear it just looks bad. The 255/35/18 tire is actually a 1/2" smaller than the rear tire, which will look better and it's only got an extra 1/4" of sidewall height than the 275/30/19 which also makes it look better.
Going with a 275/35/19 or 285/35/19 tire is actually the same, performance wise, as putting a lower numerically gear in the rear-end...that obviously doesn't help performance at all...ESPECIALLY if you're an auto and already have the 2.73!
To be honest, when I first planned to put C6 rims on my Z28, I bought the 255/35/18 tires for the front and 275/30/19 for the rear, but I couldn't bring myself to put staggered rims on an F-Body because it really does look odd IMO...F-Bodies can't pull off staggered rim sizes like the 'Vette can. I ended up going with 19" C6 rims all the way around....mine's the one on the right and I'm running 275/30/19's all the way around:
Old 11-08-2008, 10:35 PM
This is a picture of a Formula with 245/40/18 fronts and 275/30/19 rears:
Now compare that with this which has 19x10's all the way around w/275/30/19 tires (my front end hadn't settled yet after the spring swap, so it's not sitting level yet. It does sit level now as you can tell from the pic in the above post):
You decid which you like better...
Old 11-08-2008, 11:37 PM
99Bluz28's Avatar
My front tire size is 275/35/18, rear is 274/40/18
Old 11-09-2008, 02:29 PM
But your rear tire is still bigger than the front tire...in sidewall height and overall height. If someone was to run the 245/40/18 in front with a 275/30/19 rear, the front tire is larger in sidewall height AND overall height and it just looks odd...
Old 11-09-2008, 06:23 PM
99345hp's Avatar
i think it looks funny when you run a smaller diameter wheel on the front and have to keep the overall diameter the same. I think its because you have to run a taller sidewall. I dont know exactly what it is, but it looks funny.
Old 11-09-2008, 07:43 PM
hiltsy855's Avatar
Those tires are 1" difference in diameter. Do you have any ABS issues? I like that look BTW.
Old 11-09-2008, 08:15 PM
99Bluz28's Avatar
Lightbulb
No abs problems here.
IMO, as long as the rear tire sidewall is as talll, or taller than the front tire sidewall it will look good!
Otherwise it will just look wrong!
Also if you're worried about the tire height variation from front to rear, IMO just get F. 18s, R. 18s or F. 19s, R. 19s .
Old 11-09-2008, 08:19 PM
twitchtwice's Avatar
with 17/18 you want 40/35 to compensate and make them the same diameter.
Old 11-09-2008, 09:40 PM
hiltsy855's Avatar
For a 17/18 combo how about 255/45/17 front (26.0"d) and 275/40/18 rear (26.6"od)? The front sidewall is only 1/4" bigger. Sumitomo HTR Z II's are cheap in those sizes. I know you guys will think they're too big but I like the wheelwells filled up.
Old 11-09-2008, 11:35 PM
99Bluz28's Avatar
Thumbs up
I would either go with Frt. 245/45/17, Rr. 275/40/18,
or Frt. 255/45/17, Rr. 285/40/18s
Old 11-10-2008, 10:02 PM
hiltsy855's Avatar
That sounds cool but I can't find anyone that makes those sizes (reasonably priced).
Quick Reply: tire size for 18/19 in. wheels
