What rear??
Old 11-06-2008, 08:02 PM
who281's Avatar
Default What rear??
My stock 10 bolt is about to give on my bolt on car...so its time to upgrade..
eventually..hopefully soon.. the car will be getting a 402-408 with a procharger or custom turbo set-up..
so what would be my best bet for a new rear end?
Old 11-07-2008, 04:17 AM
EPP
EPP's Avatar
I would use either the Moser 9 inch or the Moser M9. The Moser 9 inch shown here, http://www.exoticperformanceplus.com....html?item=145 is less money than the Moser M9, but the M9 also comes with a torque arm and a transmission crossmember, and the M9 weighs a lot less. Here is a link to the M9. http://www.exoticperformanceplus.com...html?item=1324 Bob
Old 11-07-2008, 07:15 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
stroker with FI = 9 inch no doubt. there are fabricated housings and the stamped stock style 9 inch available. Moser 9 inch is the most economical, but if you are upgrading the torque arm the fabricated housing is the way to go. if 9 inch isn't in the plans, the the Strange S60 is a great bolt-in rearend that will stand up to the abuse easily. the S60 is the best strength vs. cost rearend out there, but is a bit heavy. any way you go the prices start around 2500.00. you will want a good driveshaft also, as it will be the weak link when the rearend is in there.
