Used 9" Center
Old 11-06-2008, 10:27 PM
Vicinity's Avatar
Default Used 9" Center
What vehicle should I look for when looking for a used center section for this axle?
http://www.exoticperformanceplus.com...html?item=1116
And is the center section all I need to directly bolt it in (aside from maybe the driveshaft)? And how much do they generally cost?
Old 11-06-2008, 11:26 PM
nealws6's Avatar
ther found on old ford's, got mine from old f-150. cost me $90
Old 11-07-2008, 12:33 AM
Vicinity's Avatar
Do you know what ratio it was?
Old 11-07-2008, 07:26 AM
usmc320's Avatar
Go to google and search for Ford 9 inch. There are a bunch of websites that will tell you what vehicles they came out of, the differences in center sections, what gear ratios, positrac, and how to identify them.
Old 11-07-2008, 01:12 PM
nealws6's Avatar
had 275 gear, but i bought a spool and 411 gears to put on
Old 11-08-2008, 02:36 PM
Vicinity's Avatar
And it will just bolt into the case and work with gears and spool/locker/posi/whatever?
Old 11-08-2008, 09:08 PM
Vicinity's Avatar
Also, how can I tell the amount of splines the section has?
Old 11-10-2008, 12:12 PM
Vicinity's Avatar
Bump going to get one soon so I need an answer.
Old 11-10-2008, 12:49 PM
95maroz28's Avatar
most of the big block cars/trucks with 9" had the 31 spline like 390 thunderbirds, trucks, etc. majority of the smaller small block cars had 28 spline. you could tell by pulling an axle and counting the teeth..theres probably another way to tell i just havent looked at them in a while to know the difference. theres a 31 spline in this old 65 thunderbird in the yard and i have another 28 spline 9" that was pulled out of a 69 cougar. whatever you do make sure its a 9" and not a 8" haha
Old 11-10-2008, 01:34 PM
Vicinity's Avatar
Would it be likely that most F-150's have 31 splines?
Old 11-10-2008, 06:35 PM
sreve's Avatar
yes and no i have seen 300ci 6s w\31spline and big blocks w\28
most all pickups with a 9" used 3:55 gears
Old 11-10-2008, 06:56 PM
sreve's Avatar
those housings\axles are not too bad on price. i was looking on the site
and did not see the torque arm for that setup.
i need to do some research on making my 3 channel a 4
Old 11-10-2008, 06:59 PM
95maroz28's Avatar
ive seen a few 67-75 f150s with a 28 spline 9" and some with a 31 spline. f250s would more than likely be a 31 spline i would think. also seen some with 3.25 gear. another thought... there should be a tag on most rear ends with a code for gear ratio/spline/ open or posi.
Old 11-14-2008, 08:55 PM
TireSm0ke's Avatar
With that housing (front loading) would it bolt up to the stock torque arm?
Old 11-14-2008, 09:13 PM
Vicinity's Avatar
I'm pretty sure it's supposed to, but you be better off asking Bob @ EPP.
Old 11-15-2008, 11:58 AM
LM97Z's Avatar
If you can find one, the full size broncos came with 31 splines, some were the "N" case too, but you'll be hard pressed finding one, they have scavaged them all up, you'll will most likely be better off putting together a new unit, because if you do come apond a used complete posi 3rd. member, it'll set you back 300+, then you don't know how wore out it is, i got f$cked on a used 3rd. member off e-bay, had to have it completely rebuilt, was out 500 bucks, i went with a spool & 4.11s, so in the long run i was out 850+ $$$, i could have gotten a nice NEW "N" unit for that kind of money (didn't listen the 1st. time ), IMO, DO NOT buy one off e-bag, you'll most likely get taken & have a junk 3rd. member, because most are the 4 pin trak loc unit, over time the 2 smaller pins wear, when this happens it wears the posi unit too, then you have a junk piece because they can't be fixed.
This piece.
Old 11-15-2008, 12:05 PM
LM97Z's Avatar
Don't think it will without modifying it to the point it will be weak (very weak), i talked this over with Bob @ EPP when i got my housing from him, i had to buy an aftermarket T/A, i got a BMR, i had the Edelbrock T/A, but this arm is pretty close too a stock one, it wouldn't work either, you know you'll also need a different driveshaft too, the stock one is an inch or so too short. The front bolt on the T/A will go in, but the rear bolt won't, the bracket for the T/A on the 9" is very thick, so you'll be grinding the rear bolt area too the point there will be no reinforment left, thats not good.
