symptoms of intake leak?
the car is doing this weird surgeing, around 2k, if I open it up it goes away, it'll idle fine, but it seems like if it gets to operating tempature then cools for a little while then driven again this problem is there, I'm thinking cracked intake, any ideaws? no ses light
Re: symptoms of intake leak?
There's always the old carb cleaner trick. Spray some carb cleaner around where you think the leak is and if there is a leak it'll suck the carb cleaner in and rev up a little.
could this cause any problems on a LS1?
like a fire lol
joel
it means your maxed out lean.
make sure your MAF screen doesnt have a dirt,leaves etc... on it.
mine was doing that and it was becuz of that
dude!!!!
You should never see stuff in your MAF screen!!!!
put a better filter in...and check for leaks.....
BAD BAD news if your getting huge debris on the MAF
a while ago changed cam, chain, pushrods, valve springs, headers, spark plugs, all the gaskets and seals were new, the only one I skiped on wuz the valve cover gaskets cause the old ones looked perfect! a few weeks back right after I filled up with gas, the ses light came on and wuz sputtering, I thought it wuz bad gas, so drained the system, put new filter and put fresh gas and seemed ok,
dude!!!!
tell me about it lol
i couldnt believe it.
i was searching for a week before i decided to check it. i was changing plugs,fuel filter etc.. lol
its stock w/ stock paper filter
