newb pinion angle question
Old 11-07-2008, 03:38 PM
noregretz999's Avatar
Default newb pinion angle question
OK I understand the formula to get it and what I need to set it to.
My question is how the hell do I use the on car adjuster?
http://www.umiperformance.com/images/2205h.jpg
Old 11-07-2008, 03:52 PM
do I need to take off the bolt?
Old 11-07-2008, 03:55 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, back the locking nuts off at the front of the adjuster and the rear. Use a wrench to turn the adjuster until you get the setting that you are looking for. Then tighten down the locking nuts and your done. Make sure you do this with the car level and the suspension loaded.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-07-2008, 04:05 PM
by the front nut you mean the nut towards the front of the car right?
if so do I leave the back locking nut on the rod end locked against the adjuster tube thing?
Im not sure if im just not getting this or my adjuster is broken or something. I actually have a wolfe arm but was using the pic as a reference. when I loosen up both of the locking nuts and turn the adjuster, nothing changes it just spins between the arm and the rod end. The rod end moves out of the adjuster and the threaded part of the adjuster will move into torque arm if that makes sense.
So do I need to leave the back locking nut locked onto the adjuster, with the front one loose, and THEN spin the adjuster into or out of the arm?
Old 11-07-2008, 04:12 PM
oh ok i misread your 1st post. So I do need to loosen BOTH nuts. but even then it doesnt move at all? Am I doing something wrong?
Old 11-07-2008, 04:15 PM
BMR Tech2's Avatar
It should move after you back both of those nuts off.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-07-2008, 05:51 PM
ok I got it thanks!
