Professional products thottle body
Old 11-07-2008, 07:18 PM
Chrisd000111's Avatar
Default Professional products thottle body
does any have a professional products throttle body? if you do can you tell me a little about the quality and if it sticks at all? im a little tight on money thats why im looking at this one.
Thanks
Old 11-07-2008, 08:41 PM
mhissstic's Avatar
If your tight on money I hear the Summit Racing ones are not too bad and do not stick (plus cheap)
Old 11-07-2008, 08:43 PM
Elliott's94Z's Avatar
I'm running the Professional Products Throttle Body. The quality is not bad at all.
^^ This is a very old post
Old 11-07-2008, 09:33 PM
Puck's Avatar
I ran one for a while that was fine on a bolt-on car as-is, and after the idle air hole mod was fine with the H/C package. Did not ever stick on me and I did not have any complaints.
I changed to an AS&M basically for the "bling" factor since it is a trick billet piece instead of sand cast. It also needed the idle air mod as well, so performance and drivability wise they were identical, on difference being a few hundred bucks on the price tag!
Old 11-07-2008, 09:51 PM
Marc3.4V6's Avatar
fyi, as far as sticking, I've got a stock TB bored to 54mm and it sticks occasionally, it doesn't return all the way to the stop and the idle is like 2-300 rpms higher. I think it has something to do with one of pieces being painted.
Old 11-07-2008, 10:28 PM
what is idle air
Old 11-07-2008, 11:29 PM
thanks guys i think i am going with the professional products tb
Old 01-31-2009, 07:42 AM
toy96ta's Avatar
I'm looking at a 58mm model for my LE2 upgrade. Would you go with PP again, or would a used BBK be better?
Old 01-31-2009, 07:52 AM
joelster's Avatar
I rock the Summit 58mm. It is a very nice piece, and was $249 iirc.
Old 01-31-2009, 10:25 AM
BBK IMO...it's what I'm running with my LE2 set up. Not that the PP are garbage I just think the BBK's are a better quality built throttle body. I had a couple Professional Product TB, sold one to a guy on here and ran the other for a short bit and sold that one as well.
