fueling needs for 800
I need to know what kind of fueling setup i should go with on my 02 a4 camaro. It is about to be making 7-800 rwhp. I know ill have to replace my pump and fuel lines and fuel rales.... what size line, where do i get it and is there a resonably priced kit? someone let me know... oh and not sure if it will be turbo or procharger... what size injectors? (forged 346)
Checky out Nasty performance. They are a sponser on here, you will be dealing with Nate. I went with magnafuel inline through him. Some go inpump, i wanted one system that would handle enough for no matter what i did. This may be overkill but if you want to run e85 id consider it. I think my supply line is #8 and return #6 magnafuel pump 4301... Nasty fuel rails and magna fuel regulator.
He is good to work with and very helpful look him up.
For injectors for that much HP on forced induction I would reccomend our 83lb Siemens injectors.
They are brand new, high impedance so you can run the stock ECU. And I can get them with the correct connectors for your car.
I can do them flow matched for $90 each
I was hoping for some in tank pumps and or something thats not visible like the one pictured above... live in houston that pump would disapear if it was in plain view like that.
