cam install help please
Old 11-09-2008, 11:06 PM
mglooper's Avatar
Cool cam install help please
hey i was looking through the cam install because i plan on doing it this weekend but i was wondering if i could get the dimensions of the metal tube i would need to keep my lifters from falling while doing the install? i couldn't really find it using the search so any help would be appreciated
Old 11-09-2008, 11:08 PM
BatmobileSS's Avatar
Pretty sure it's 5/16. I used wooden dowels and rounded the edge I inserted. Worked like a charm.
Also for what it's worth just use the TDC method when changing springs it worked a lot better for me.
Old 11-09-2008, 11:42 PM
blackLS1m6's Avatar
5/16" is the correct size. Spin the cam a few revolutions to get the lifters in the lifter trays. Some may not stay in the trays. I used 5/16" steel rods on my car. You could also use the pen magnet method to hold the lifters, get 16 pen magnets if you want to do it that way. Good luck.
Old 11-09-2008, 11:57 PM
mglooper's Avatar
what tool did yall end up using for the spring compression and do you think it would make a difference? also is the longer crank bolt necessary? and where could i get one? also would it matter to round the edges on the metal tube?
Old 11-10-2008, 12:51 AM
Droptopws6's Avatar
I used the crane install tool (CRN-99472-1) for the springs, it was nice to do two springs at once. I also have a harmonic balancer install tool I bought from a guy on this site (618HAWK)
Old 11-10-2008, 06:46 AM
01ssreda4's Avatar
i bought tims valve spring tool
Old 11-10-2008, 02:40 PM
mglooper's Avatar
have any of yall used the auto zone tool? i just dont feel like spending 130$ and then shipping for a tool i will only use once
Old 11-11-2008, 05:40 PM
mglooper's Avatar
anyone else have .02 cents?
Old 11-11-2008, 05:44 PM
Super Speed's Avatar
Don't use the autozone one, you can get the pulley there though... I recommend the crane tool as well but if you are short on cash get Tims tool its relatively cheap!
Old 11-11-2008, 05:48 PM
mglooper's Avatar
do i need a new pulley or if you were referring to a pulley puller i already have one. anyone know about where to get the longer crankshaft bolt? and how much easier is it to do either the TDC method or the air tank one?
Old 11-11-2008, 06:06 PM
01ssreda4's Avatar
tdc method is a breeze...
Old 11-11-2008, 06:10 PM
mglooper's Avatar
dang right after i sent the money for tims complete kit
Old 11-11-2008, 08:15 PM
Atver300's Avatar
I used the autozone tool that grabs the spring fromt the top and bottom and compresses it. I bought a long crank bolt from napa and used 5/16 wooden dowels from lowes to hold the lifters up. I rented the compression tester from autozone and hooked it up to my aircompressor via the drier and regulator for my paint gun to hold the valves open
Old 11-12-2008, 03:13 PM
TDC for the valves works great!
