im currious about my setup
Old 11-09-2008, 11:37 PM
speeedo's Avatar
Default im currious about my setup
hi i`m very currious about my setup what you think i will get in dyno ??? still not tuned and didnot run it on dyno
z71 2000
strocker 408 (11:5 compression )
Patriot Performance GM LQ9 Stage III
ms3 cam
Pacesetter QuickTrip Long Tube Headers
ls6 intake
bbk tb
afe air intake
Timing Chain
ARP Head Studs
4L60E tranny is stock with a transgo kit
No Exhaust system or catback only 3` tube stock
Old 11-10-2008, 04:14 AM
Abdullah's Avatar
i would say around 460-470 rwhp.
Old 11-10-2008, 04:17 AM
lemons12's Avatar
450ish depending on the dyno... probably not lower, just higher..
Old 11-12-2008, 10:58 PM
speeedo's Avatar
i tuned my truck and run it on the dyno and i was very Disappointed i got 388rwhp and 390 rwtq but when i run it on the street it was greet i think the dyno dont give real number on trucks for sum reason i dont know ?
with ms3 and the Patriot heads its run good i think i`m going to get fast intake and tb
Old 11-12-2008, 11:07 PM
lemons12's Avatar
wow, thats odd... i would go to a different dyno next time man...
if not, maybe a comp. check?
Old 11-12-2008, 11:14 PM
speeedo's Avatar
lemons12
thanks for your fast replay but i`ll like to know what you mean by comp. check?
Old 11-12-2008, 11:22 PM
lemons12's Avatar
lemons12
sorry, compression check..
reason i say... i made 385rwhp with my ls1.. ms4 cam ported 90/90 full exhaust 4k stall 410s.. i didnt even have heads on it... and that was on a dyno that reads about 20 hp low....
with my heads i am expecting somewhere around 425rwhp...
i think something is waaay wrong.. just try a different dyno and then go from there..... if you dont get anyone to tune it... if you just go and put it on the dyno for 1 run to see what it does.. you should be able to get that for like 30-40 bucks.. something like that
Old 11-12-2008, 11:33 PM
speeedo's Avatar
ok i will run it in different dyno tonight and i did a compression check and its 11:5.1 but i`m sure i will get the same number i think my ls6 intake stoping me from getting high hp number
Old 11-12-2008, 11:49 PM
lemons12's Avatar
it should not be restricting it THAT much.....
but who knows? anythings possible...
what kind of dyno you using?
Old 11-12-2008, 11:54 PM
speeedo's Avatar
dynojet
