Question about TA relocation bracket
I am inexperienced with the correct measurements and angles so........I bought the TA relocation bracket from BMR and it had different holes that i can adjust the TA location up and down. Does that need to be at a specific spot. Can that cause vibrations if not at the correct spot. If so how do i figure out where it needs to be set? Does this have anything to do with the pinion angle?
The adjustment in the front is going to change several things at once. If you like give me a call here at the office and I can go over all of what needs to be taken in consideration....
