are 01+ 28lb injectors sufficient for H/C?
Old 11-10-2008, 06:58 PM
scottHMT's Avatar
Default are 01+ 28lb injectors sufficient for H/C?
I am doing a h/c install, the parts finally arrived today, I am using 01+ 28lb injectors in my 00 z28. Should 28lbers be good for a torquer v2 and TSP stg 1.5 5.3 heads? Or should I get something else?
Old 11-10-2008, 07:16 PM
memphisTa's Avatar
I thought 01's had 26#
Old 11-10-2008, 07:19 PM
LSX Mechanic
Damian's Avatar
Stock 28's are good until about 480rwhp, then it's time to upgrade. You should be fine for what you're planning.
1998- 28 lbs
99/00- 26 lbs
01/02- 28 lbs
Old 11-11-2008, 12:12 AM
Bouvs's Avatar
stock injectors good for up 480rwhp? Thats seems completely unrealistic... seems like most guys run into their stock injectors hitting 95% cycle duty after mild h/c at around 420rwhp... besides if you can help it you want your injectors running around 80... look up Racetronix for some help on injectors.
Old 11-11-2008, 12:57 AM
KMS.1320's Avatar
I upgraded to a racetronix pump and harness, and disc style 42#'rs just to be safe.
But TSP heads/cam combo tend to be pretty mild, so you may be ok.
Old 11-11-2008, 01:04 AM
Hamrdown's Avatar
[QUOTE=Damian;10457788]Stock 28's are good until about 480rwhp, then it's time to upgrade. You should be fine for what you're planning.
I think that's for M6 cars. Auto's exspecially stalled autos dynos will be alot lower and IMO should consider injectors when around 430rwhp. Either way your tuner will be able to tell you when they look at your tables when tuning.
Old 11-11-2008, 01:07 AM
KMS.1320's Avatar
Don't take that number as fact anyway. My injectors on my 99 went static (100% DC for you n00bs) at 6100 and my cam doesn't peak until 6500.. and that's with mildly worked 243's. There's no way that car is pushing 480rwhp right now.
Old 11-11-2008, 01:09 AM
Hamrdown's Avatar
1998- 28 lbs
99/00- 26 lbs
01/02- 28 lbs[/QUOTE]
That's correct!
Old 11-11-2008, 01:16 AM
scottHMT's Avatar
well i have a m6, so these should be fine, hopefully
Old 11-11-2008, 10:23 AM
JBIRD02's Avatar
Well fwiw, I was told my 28's were @ 97% and I'm cam only.
So I picked up a set of 36's that I'll be installing along with my heads.
Old 11-11-2008, 12:00 PM
Tuner@Straightline's Avatar
01/02 injectors will reach 100% duty cycle around 410rwhp (A4), or 420rwhp (M6) on our Mustang dyno.
Old 11-11-2008, 12:53 PM
eamador11's Avatar
I agree, you want at minimum 30lb for any H/C
Old 11-11-2008, 12:57 PM
LSX Mechanic
Damian's Avatar
I ran 98 injectors on a 470 rwhp setup for 3 years with no problems. Built 4-5 heads/cam setups this year in the 450+ range with stock injectors and no problems.
You do not need bigger injectors for a heads/cam swap unless it's a max effort 346 (Trick flows, FAST, huge cam, etc etc etc)
Old 11-11-2008, 01:03 PM
SSpdDmon's Avatar
Isn't the rule of thumb something in the 20 m-second range? Isn't it at that point that the injectors are pretty much static?
Old 11-12-2008, 09:24 AM
Ideally you'll want the injectors to be in the 85% duty cycle range or lower. Higher than that, and the injectors ability to atomize the fuel is decreased.
Old 11-12-2008, 10:10 AM
ChevyRyda99LS1's Avatar
I was wondering the same thing I got some summit 30lbs in there right now but I'm suppose to get some 42's right before I get on the dyno I just want to hit 400. The guy thats suppose to give me the 42's might flake on me though so I'm hoping to be able to get to 400 with my current setup and the 30's
Old 11-12-2008, 11:36 AM
As far as injectors go, going from 28lb injectors, to 30lb injectors give you a 7% increase, meaing at the same power level, you're duty cycle would only decrease by 7%, so if you're at 100% duty cycle, then you'd still be at 93% DC with the 30lb'ers. With 36lb'ers you have a 28% increase in capacity, and with 42lb'ers it's a 50% increase in capacity.
Old 11-12-2008, 11:55 AM
02sleeperz28's Avatar
^Listen to this guy he knows his ****, I had a 02 z28 A4 heads, cam and stall and if I remember correctly the stock 28s were at 90 something duty cycle and Straightline recommended 42 pound injectors. The new owner put 42s in there and the car runs excellent now. Get some 42 pound injectors!
Old 11-12-2008, 12:18 PM
TORCHD 02 TA's Avatar
1998- 28 lbs
99/00- 26 lbs
01/02- 28 lbs
i would have to disagree.. My 02 Trans Am has stock 28.8# injectors. With my CAM ONLY set up i am making 415RWHP. My duty cycle with my stock injectors is ay 98% At 108% it spraying all the time.
OP, i would upgrade to 42# injectors, that is what i am going to be doing
Old 11-12-2008, 12:20 PM
rnl35thss's Avatar
On my '02 H/C w/stock fuel system, the injectors were going 100% @ 6450 (just below peak, 400rwhp) and were at 85% at 5600. I just installed a racetronix pump and harness thinking a volume/pressure problem but haven't scanned it yet to see if that solved it. If not I'll stick bigger injectors in it.
Quick Reply: are 01+ 28lb injectors sufficient for H/C?
