Changed MAF and car feels slower
Old 11-10-2008, 09:49 PM
Bluvette28's Avatar
Default Changed MAF and car feels slower
Why does my car feel slower after i put the slp MAF sensor in my car?
Old 11-11-2008, 01:14 AM
KMS.1320's Avatar
because it might be.. maybe it isn't calibrated correctly?
Old 11-11-2008, 01:54 AM
jsteele90's Avatar
gm unmodded maf is the only one ill run on my car
Old 11-11-2008, 02:52 AM
kdavis's Avatar
you need to tune the computer to pick up the higher air flow. however we did have a 402 that got 2 tenths faster after we put on a bigger granitelli one with same tune.
Old 11-11-2008, 08:30 AM
99_Z28's Avatar
The stocker is fine up to 400+rwhp.
Old 11-11-2008, 08:46 AM
streetassasin's Avatar
^more like 500rwhp, The only reason not to run the stocker os if your on a SD tune
Old 11-11-2008, 09:43 AM
Bluvette28's Avatar
well how do i tune it? Can i use a handheld tuner because i have hypertech but i dont know if that will work with it.
Old 11-11-2008, 09:47 AM
Benner's Avatar
Honestly your better off taking it off and reinstalling the stock MAF. Seen several people have nothing but trouble. Plus it'll probally cost you over $100 to get it tuned correctly with that maf
Old 11-11-2008, 10:52 AM
LS1-450's Avatar
It's very simple to re-calibrate your MAF table. It's done all of the time. Although, I don't think your programmer has the capability. Where are you located?
Go to the tunning section & start a thread requesting help w/ re-scaling your MAF table & note your general location. There's a good chance that a member will help. If not, a local tuner can do it for a nominal fee.
Old 11-11-2008, 10:54 AM
most tuners wont touch a car with a aftermarker MAF
Old 11-12-2008, 06:22 AM
Internet Mechanic
BlackScreaminMachine's Avatar
FYI, at Wide Open Throttle (WOT) The MAF calibration means nothing.
Most likely he is speaking about part throttle acceleration. In theroy, if it was a restriction the more air you can flow the more power the engine makes.
Old 11-12-2008, 06:23 AM
Internet Mechanic
Agreed, because they must adjust their tuning to consider the MAF's aftermarket calibration.
Old 11-12-2008, 06:51 AM
LS1-450's Avatar
Have you had any luck finding help?
