To Mill Or Not To Mill PRC Stg 2.5 5.3 heads
I'm soon to be installing a set of PRC Stg 2.5 5.3's with a 224r cam and using cometic .040 gaskets. To bump the compression even more the heads are going to milled- not sure how much but Jon from Texas Speed says i will end up at approx. 11.3:1 comp. Now, as i read through the forums, some people advise against milling these heads particually if using the cometics .040 gasket for reasons given that a small cam such as the 224r does not like that much static compression.My question is 'why not'.
Vehicle details is as follows: Wieght is 2950lbs, manual,1 3/4 headers, no cats open exhaust, 98 octane fuel, 3.45 diff and the car is used for circuit racing. I,m trying to build a budget torque monster.Also, anyone want guesstimate h/p and tq #'s.
Cheers
Cheers
The reason you have to watch your compression is because of detonnation. It is not SCR (Static Compression) that is the issue, it is DCR (dynamic compression).
224R is a XE-R lobed cam, but is it on a 112+4, 112+2, 114+4 ??
That has an effect on DCR.
Any ways, with .040 gaskets I advise no mill on 5.3L heads. That should give ~61cc and 11:1+ SCR. Perfect on all counts.
Thanks all
IMO, the 228r is better suited I believe off shelf is 228/228 .588/.588 112+2 LSA
with unmilled heads and .040 gasket you are looking at ~10.8x:1 SCR and ~8.70 DCR
Perfect on fuel demands and cylinder pressures.
