L92 milling question
Guys, I am running a 6.0 LS2 and I have installed a Vengeance cam 224/235/610/620/115 and it runs awesome.
Here is my question.
I will be picking up a set of TSP CNC'd L92 heads (stock size valves) and I am having them milled .020 and need to know if the current 7.4 push rod will work? Anyone have any ideas?
In other words, if you mill only .020 off a head, will you be required to get a different set of push rods? I have been into Cobras for so long, I can't remember!
Stock LS2 pistons
Going to run Cometic's btw, if possible.
Stock LS2 pistons
LS1Tech Premium Sponsor
First, do you have valve reliefs for this combo? I'm afraid that exhaust lobe might cause some issue between pistons and valves. What lifters will you be running? With a .053" GM MLS gasket, you're should be in the area of 7.35-7.375" pushrods with the heads milled .020"! 7.375" will likely set you up close to .080-.100" preload.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
First, do you have valve reliefs for this combo? I'm afraid that exhaust lobe might cause some issue between pistons and valves. What lifters will you be running? With a .053" GM MLS gasket, you're should be in the area of 7.35-7.375" pushrods with the heads milled .020" 7.375" will likely set you up close to .080-.100" preload.
I will verify that with Ron from Vengeance as well.
How did Jason have the heads set up when he ran them on his A6 I wonder. Stock compression maybe or a smaller cam.
Jason's old car just has a 228R camshaft IIRC....GM MLS gasket, stock valves (they have better clearance than stainless), and only enough milling to ensure the heads were flat. The largest I've seen clear this combo recently was a GTO guy (ShoddyDog if you browse the GTO forums)...I cannot remember his PtoV clearance off hand though. He ran a 228/232.
__________________
That is correct!
__________________
Just commenting here but I have an LS2 with L92 heads. My pistons have no reliefs in them. My heads were milled .040. I run a stock ls2 head gasket and my cam is comp xer lobes 232/242 .595/.610 113lsa. I dont have any PTV issues. My pushrods are 7.350. Hope I could help.
