oil feed question
Old 11-11-2008, 02:57 PM
eviltwin_1987's Avatar
Default oil feed question
i want to run the factory oil cooler line but need to know where i can tap for my turbo feed line. can i go where the plug is on the side of the cooler block?
Old 11-11-2008, 07:43 PM
exploder's Avatar
remove the plug from the drivers side of the block right next to the timing cover
Old 11-11-2008, 08:02 PM
im gonna guess and say thats not filtered.
Old 11-20-2008, 11:10 PM
busta9876's Avatar
Nope not filtered.
I'm planning on feeding off the cooler line port in/out. My engine does not have cooler, only aluminum part to redirect backinto oil pan. I'm going to drill/tap for oil pressure source.
Old 11-28-2008, 08:22 PM
dhdenney's Avatar
OK very similar situation. I'm not real familiar with how the LS1 oil passages run so I drilled out the blocking plate on the oil pan. It was perfect for a 1/8" NPT tap and then I installed a -4 fitting in there. Then I had an after thought. The two holes are undivided coming coming into this plate. Is this like a feed and return for the oil cooler cars? I just don't want unfiltered oil going to the turbo.
Old 11-30-2008, 07:03 PM
busta9876's Avatar
Oil cooler is exactly what thats for. It IS filtered oil. I verified this by tracing the passages in the block/oil pan when I had my 5.3L apart.
Old 11-30-2008, 07:11 PM
dhdenney's Avatar
I had traced the passage down and assumed that I was good but I didn't wanna make a fatal mistake based on an erroneous assumption.
Quick Reply: oil feed question
