High 11s Low 12s
High 11s Low 12s
iam doing a 383 w the gm847 cam shooting for high 11s low 12s on motor...i have ported stock heads, yanks 3600 stall, mt drags radials,Lts w ORY, ect ect you guys get the point...do u guys think this goal is in reach...and wat r some pointers u guys can give me...i want to be somewhere around 400hp..
You should be able to reach your goal of high 11s low 12s cam only, or atleast with a stock bottom end. If you haven't started the build, I'd recommend you buying a nitrous kit and holding off on the 383. Save yourself a few grand on the build and spray your way to high 10s and maintain daily driveability. Just my .02.
Small cams can get it done too. Stock block, trans, and rearend. It has some suspension pieces but sits on Eibach Pro lowering springs and stock shocks. Gotta love those MT street radials. 12.0xs in the heat, and low 11.9xs in good air.
