Quick Diamond Piston Q (FI)
Re: Quick Diamond Piston Q (FI)
3.905 is the most common overbore size. That would be a shelf piston too so they are cheaper then customs, unless you need some custom for high FI use.
There is a shelf 3.905 with a -8.6cc dish available. You'll just have to plug in your stroke, gaskets, and CCs and get the compression, or let me know the numbers and I'll do the math. Other then that it's going to be a custom.
Paul
Paul
We can also turn down the shelf stock pistons we have to std. bore. Our cost to do that is $30.00.
Remember also, that #11503 is our turbo/blower piston. It was designed to handle up to 20lbs of boost. With 70cc heads it should give you around 9:1 comp ratio.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
Thanks,
Chris Gelineau
Diamond Pistons
And on a side note, You can get your Diamond pistons from LG Motorsports,
Let us know if we can help you.
Thanks
Lou Gigltiotti call toll free at 877-LGMotor
Thanks
