Need Gasket Part Numbers
Hey i was wondering if i could get part numbers for a few things,
1. GM impala Head gaskets
2. LT1 intake manifold gaskets
3. Throttle body gasket
4. Opti-spark seal
5. timing chain cover gasket
6. Crank seal
7. Water pump drive seal
8. Water pump gaskets
also can i re-use my valve cover gaskets?
If ya cant tell i'm doing a cam swap and fixing a blown head gasket and want to bump the compression slightly. Will prolly order all this stuff from summit so part numbers for there would be awesome.
Thanks!
4. Opti-spark seal
6. Crank seal
Thanks!
part numbers listed are for 95 LT1.
The head gasket I listed in called the LT4 .028 gasket, not sure it that's the same as the Imp gasket?
1. LT4 .028 Head gaskets - GM part # 12553160 ( Sold individually)
2. LT1 intake manifold gaskets – GM part # 12524653
3. Throttle body gasket 48/52MM - GM part# 10105379
4. Opti-spark seal – GM part # 12552428
5. timing chain cover gasket – 10128293
6. Crank seal - GM part # 10128316
7. Water pump drive seal GM part # 10217886
8. Water pump gaskets – GM part # 10128343 - need 2 (Sold individually)
9. Vent tube gaskets - GM part # 10108689 - need 4 (Sold individually)
They are for the coolant tube on the back of the heads that runs up along the passenger sid of the intake. There are 4 gaskets, two on each side. Whenever I do a swap I replace them, they can be reused most of the time, but once everything is back together if they leak they are a PITA to work on, so I just spend the few extra dollars and replace them.
