what size injectors?
For that power level you will need to go low impedance 65lb Delphi, or the high impedance 75lb Siemens.
I have both, $79.95 each for the Siemens, $69 each for the Delphi.
But keep in mind, you will need an aftermarket driver box or an aftermarket ECM to use the low impedance Delphi's.
