Do 1.8 rockers normally require longer or shorter pushrods..?
Depends on current rockers vs. new rockers. For example, the Crane kit comes with 7.250 pushrods. If the pushrod cup is moved to obtain the higher ratio, you need to verify pushrod length and it is the pushrod cup that is altered to obtain 1.8. Bottom line, verify your length.
