Fuel system
Fuel system
I have tried searching, and tried contacting a few sponsors. I'm trying to figure out if my current fuel system will support safely my turbo setup.
Right now I have the walbro 340 intank pump which I guess is the walbro 255?
I also have 60 lb injectors.
Will this be sufficient enough fuel/injector setup? Also, am I supposed to have a external regulator that is boost referenced or does the intank pump suffice? I plan on running 10psi. Let me know what you guys are running or what I should do to upgrade.
