How can I tell between a LS1 and LS6 block?
Old 11-12-2008, 05:53 PM
no title here
skyhighsami's Avatar
Default How can I tell between a LS1 and LS6 block?
I got a 2002 LS1 block and I heard that some of the 02 F bodies got LS6 blocks. What would tell me what block I have, engine markings or something.
Old 11-12-2008, 06:49 PM
Grimes's Avatar
gotta look at the number on the back of the block with a mirror. if you do a search, you will find all the info you need!
Old 11-12-2008, 08:24 PM
JBIRD02's Avatar
Yep, lots of info on this subject if you do a search, but I believe the # to check for is 12561168. It should be on the back of the drivers side near the transmission.
Old 11-12-2008, 09:22 PM
no title here
The marking on my motor was 12559378
Old 11-12-2008, 09:34 PM
vsocks1's Avatar
I believe that is 2001 up LS1 then.
Old 11-12-2008, 09:51 PM
LSX Mechanic
Damian's Avatar
02's did not get the LS6 block. That is a rumor, unless it was replaced at a later date. I've been around and/or worked on 50-60 2002 F-bodies the past couple years, and have yet to see one that had an LS6 block in it.
One tall tale sign would be the LS6 valley cover.
Old 11-12-2008, 10:10 PM
INMY01TA's Avatar
I don't think f bods with LS6 blocks came with the LS6 valley.
Old 11-13-2008, 11:44 AM
Z28M6TT's Avatar
it was something like 15% of the 01's and 20% of the 02's had LS6 blocks. i checked mine when i did my clutch and it was the 12561168 (the LS6). its NOT a rumor, but if you have it, it doesnt mean you have an LS6. you still have LS1 internals with LS1 heads. the LS6 heads were the 243 casting number, not the 241s. the only benefit you really have with an LS6 block with LS1 internals is it has better oiling properties. supposedly (and dont quote me on this) the LS6 block is one of the best blocks GM ever made for oiling.
also if you decide to do different heads with forged internals, than you can say you have a worked LS6
Old 11-13-2008, 03:09 PM
vettenuts's Avatar
I just checked my 02 Vette (non Z06) and it has the LS6 block.
Old 11-13-2008, 03:16 PM
Shawn MacAnanny's Avatar
I thought there was also extra 'webbing' around the cylinder walls?
Old 11-14-2008, 10:25 PM
1BigEgo's Avatar
Do you know how many 02's got the ls6? I plan on getting a ls series ss camaro when i get back from afghan.
Old 11-14-2008, 11:53 PM
fastmatt98's Avatar
Checked my engine from my 01 SS vert the other day while it was sitting on the shop stand and it is
12561168. Kinda made me feel all warm and fuzzy inside lol.
Old 11-15-2008, 04:31 AM
Keenov's Avatar
Haha, my '02 Z28 has a LS6 block in it Motor hasn't been replaced yet. It was built in 05/02
Quick Reply: How can I tell between a LS1 and LS6 block?
