What sensor is on top pf the rear end?
Old 11-13-2008, 07:45 PM
slim0035's Avatar
Default What sensor is on top pf the rear end?
Was working on pulling the old 10 bolt and found something that plugs/pops/ pushes into a hole in the top of the rear end, has a smalll 10 mm bolt to hold it in place and has a wire running to the harness that comes through the floorboard. What the hell does this do? I did a quick search before posting this thread with no luck.
Old 11-13-2008, 07:48 PM
EPP
EPP's Avatar
That is your ABS sensor. Bob
Old 11-13-2008, 08:02 PM
slim0035's Avatar
That was my assumption but was not 100% sure. Thanks!
