LS2 block cylinder walls max boot psi/hp/start to balloon Any info on dry sleeves to?
Old 11-14-2008, 03:12 PM
BigRich954RR's Avatar
Default LS2 block cylinder walls max boot psi/hp/start to balloon Any info on dry sleeves to?
With a ls2 block when do you start to see the cylinder walls start to balloon
Does it just add blow by and lose a little hp ?
how strong are the stock ones ?
Whos running darton dry sleeves ?
If i crack a stock sleeve can i then add dry or wet sleeves to the block to fix it?
When do you start to see issues with the dry sleeves?
Old 11-14-2008, 05:09 PM
Also if you install a 4 inch bore dry sleeve. Then at a later time can it be bored to a 4.125 bore? Or will it cause issues with the press fit in block?
Old 11-17-2008, 06:16 AM
Anyone? Looking for the people that added 6 bolts to the stock block were you guys still running stock liners in the cylinders?
Old 11-17-2008, 06:50 AM
Fireball's Avatar
we'll be tearing down my ls2 soon to see how the sleeves (among other things) have been wearing. been making 1200+ hp
a resleeved ls2 option:
http://www.erlperformance.com/index....224&Itemid=162
Quick Reply: LS2 block cylinder walls max boot psi/hp/start to balloon Any info on dry sleeves to?
