Dope style with a ram air twist Trans cooler
Ok guys, After installing my APS kit and getting screwed by (Be Cool) on a bum rad and having tranny fluid and antifreeze destroying my tranny and all my coolant hoses ,I opted for the dope style tranny mount with a barnat ram air twist LOL Im not sure if im the first to do this or not but after drilling 4 holes in the ends of my air dam to support the B&M tranny coolers, I cut the box off off the backes of the corner air dams and flipped them upside down and mounted them on the opposite side so the luvers face down and will grab air to force threw the tranny coolers.Im probably going to use the box that was cut off of the corner air dams to box in the tranny cooler to make it even more better, thus keeping the air from going out the sides!Here's a few pics of what it looks like and I also used braided lines so for ease in replacing the starter.The steel lines are no longer in the way
http://s243.photobucket.com/albums/f...rans%20cooler/
This is the passanger side air dam that i removed the back piece off of the back and flipped over and has now became the drivers side air dam with the lovers facing down to grab more air for the tranny cooler.I used the removed piece to box in the end to keep the air flowing up verses out the side.I may exstend this piece up higher yet!
http://s243.photobucket.com/albums/f...er/air%20damb/
PS,This corner air dam when modified and flipped over just so happens to FITS PERFECTLY over the front air dam with no modifications and also when installed throws air out the back towards the front roters which is a plus and just worked out like that !
PS,Nice!!!!!!!!!!!!Burn out too my man!! LOL!!
