full bolt on heads/cam fuel requirement question
Old 11-15-2008, 12:52 AM
irocurpony8489's Avatar
Default full bolt on heads/cam fuel requirement question
what size injectors are need for a le1 headed lt1 with full bolt ons and a 224 230 112lsa 550 lift cam need? Will i have to upgrade the stock pump, rail, and regulator to?
Old 11-15-2008, 01:56 PM
robsquikz28's Avatar
u should always upgrade stock pump but if there is nothing wrong with ur stock pump dont replace it....are you having any power adder?????if not and just motor with that setup i would run 36# injectors..
Old 11-15-2008, 02:02 PM
AChotrod's Avatar
Im sure you could get by with 30# injectors but I would go with 36/37# injectors. That leave you more room for when you need it!
Old 11-15-2008, 02:46 PM
lt1z28camaro's Avatar
I just did le2 heads/cam swap and put it on the dyno, car falls on its face at 4500rpm's. Fuel pump losing fuel pressure bad! So I'm getting a racetronix fuel pump hoping this solves any and all problems! haha.
Old 11-15-2008, 02:51 PM
StealthFormula's Avatar
Yea you should get the Racetronix Fuel Pump Kit and some 30lb. Injectors will work fine with that setup. You can run more injector if you wish and it wont hurt anything but the stockers are no good.
Old 11-15-2008, 03:26 PM
Default change of plans
the motor is actually a golen 350 lt1 with the comp cc305 cam and stock ported heads 175cc head with 2.055 1.55 valves. Would my stock 24Lbs support this setup or will i need injectors or could i bump up pressure on the stock injectors? the motor is n/a with a stock 48mm throttle body and 1 5/8 shorties. I dont have a big goal id be happy with 340rwhp
Old 11-15-2008, 10:13 PM
James Montigny's Avatar
24s are going to be a bit small.
30 or 36# injectors with a stock pump and regulator should be just fine.
If the pump is old or you suspect that it will not produce enough pressure at high RPM
replace it with a Racetronix 255lph kit. Inexpensive and just as easy to install as a stock replacement.
Remember to have the tune updated for your H/C and injectors.
You should no problem at all hitting 340 ... Even with shorties and a 48mm.
Old 11-16-2008, 02:53 PM
LS1 Eddie's Avatar
I'm getting by with 30's no problem and our setups are pretty similar.
Quick Reply: full bolt on heads/cam fuel requirement question
