53mm offset question..
Old 11-15-2008, 12:54 PM
kaotikid's Avatar
Default 53mm offset question..
Hey guys!
if i got 18x9.5 (275/35) and 18x10.5 (295/35) c5 z06 wheels, with a 53mm offset, will it fit properly and will i be able to still lower the car w/o any issues??
thanks in advance!!
Old 11-15-2008, 03:28 PM
Customizing Director
MadIceV8's Avatar
You'll be perfectly fine and no modifications should be needed. Mine are 56mm so yours will come out a little bit more then mine (click sig to see photos).
ALSO if you read the STICKY you'd know that it is fine...
Old 11-15-2008, 05:19 PM
Trunion King
bene's Avatar
I'm w/ Madice. I have exactly the same wheels as yours. I have the 53mm offsets.
Old 11-15-2008, 06:36 PM
michaelg589's Avatar
yes you should be fine. When youre are lowered you MIGHT have to BFH a little. I have 18x10.5s, 295-35 and +50mm offset and i needed to.
Old 11-15-2008, 08:19 PM
kaotikid's Avatar
thanks guys. you guys were very helpful.
btw..i did read the sticky and it said 50mm-53mm would be fine. but i just wanted to make sure because tomz told me that their offsets for those wheels are 57mm (front) and 58mm (rear).
thanks again guys!
Old 11-15-2008, 10:38 PM
MadIceV8's Avatar
I think thats because those are the same as the Vette offsets and are easier to get a hold of.
Old 11-16-2008, 02:20 AM
UAZ28SS's Avatar
I have 53mm offsets on my 18x11 ZO7 wheels and I had to use the BFH on the wheel wells a bit to make them fit. Not a big deal, though.
Old 11-19-2008, 05:42 PM
kaotikid's Avatar
So will i have any clearance issues with the 53mm offset wheels and a 1.5" drop??
bene your car doesn't seem lowered in your pics, but if it is now, can you please chime in..
btw, yours and madice ride looks sick!!
thanks again
Old 11-19-2008, 05:47 PM
thanks again
you will be ok.
