retuned polluter results
Old 11-15-2008, 05:27 PM
cbr954rr's Avatar
Thumbs up retuned polluter results
i had my 02 m6 retuned today by randy at mike ward racing in columbus, ohio.fixed my hot start problem and low end drivability,its a whole different car now.it made 432whp/371tq on a mustang dyno,car made 429/388 on dynojet dyno with last tune,definitly better now,its going to be a long winter.
Old 11-15-2008, 05:39 PM
Cvaught's Avatar
What car and mods?
Old 11-15-2008, 05:41 PM
krazy4's Avatar
Originally Posted by Cvaught
What car and mods?
+1
Old 11-15-2008, 06:47 PM
bad95killer's Avatar
damn good gains on MD buddy but as they stated above more info pls. ?!
peace
Old 11-15-2008, 08:06 PM
95Lwind05's Avatar
wow sounds good give us the specs on your set up! I have a polluter sitting in my closet for this spring A4 or M6?
Old 11-15-2008, 08:59 PM
Chris05ssTruck's Avatar
I'm pretty sure it says 02' m6?
Old 11-15-2008, 11:35 PM
cbr954rr's Avatar
02 ws6 ta,m6,pace setter lts&ory,magnaflow cat back,granatelli lid,k&n,everything else on motor is stock,descreened maf,ram clutch,373 gears,sfc,lca,panhard bar,pro 5.0 shifter.
Old 11-15-2008, 11:47 PM
b00sted's Avatar
Those are nice numbers for a cam only setup. Mustang dyno especially.
Old 11-16-2008, 11:31 AM
built408's Avatar
Great power, torque is alittle low. You have the graph?
Old 11-16-2008, 11:43 AM
98camaroLS1M6's Avatar
Almost 390rwtq on a dynojet is pretty strong for a cam-only 346. Nice numbers!
Old 11-16-2008, 12:12 PM
pitbull14218's Avatar
Nice cant wait to see track times if thats planned, i need to pick a cam out but im more for the street
Old 11-16-2008, 05:19 PM
Chrome355z's Avatar
Better put 4.56+ gears on and lighten that car to 3,200ish lbs to take advantage of the power with that donkey dick cam and high RPM peak; otherwise you would run faster full weight and 4.10 gears with a low 230 cam. IMO
Old 11-16-2008, 10:03 PM
VIPERBLUELX's Avatar
that's what I was thinking
Old 11-17-2008, 08:49 AM
blu1's Avatar
Sounds like one of those happy corrected Mustang Dynos to me like the one RPM uses at Evolution in PA.
Old 11-17-2008, 08:55 AM
No way a stock headed car made 432 on a mustang dyno unless they've added a % to the number to try to duplicate dynojet numbers. Mustang dynos are heartbreakers so many of the shops convert the numbers to make the customer feel better which I think is BS.
Old 11-17-2008, 09:02 AM
95Lwind05's Avatar
you should put up a copy of your dyno and a sound clip
Old 11-17-2008, 09:03 AM
Frans96SS's Avatar
haha i love how you have something against me ..... you post in every thread about MD's.... dont get mad b/c i build cars that make power. If i make a post and the car makes the power it shoudl you say nothing. If it makes good power you say its wrong. Get a life and quit using my name in your posts.
Old 11-17-2008, 12:35 PM
sciff5's Avatar
Look up demoncbird00. His cam only Fbody put down 450+ whp through stock heads with an untouched fast 90/90 with a 12 bolt rear end and his quarter mile times back up his numbers. He also drives the car daily.
Granted its a huge cam but its deff possible to put those sort of numbers down
Old 11-17-2008, 01:04 PM
sdbrown84's Avatar
Nice numbers. With a rediculuous cam it can be possible, but I have yet to see a full dyno sheet printout with 241 heads and a big cam making over 420 hp to the wheels through a properly built drivetrane (tranny, ds, and rear).\
It's just all top end, not very balanced, but still powerful none the less.
Old 11-17-2008, 01:19 PM
blu1's Avatar
I don't have anything against you at all, I just know for 100% fact that the Mustang Dyno you use reads WAY HIGH for a Mustang Dyno. You claim everything to make these unreal numbers on a Mustang Dyno (which reads A LOT lower than a dynojet). I'm definitely not mad you build cars that make power, why would I be mad?
https://ls1tech.com/forums/dynamomet...take-c5-2.html post #26
Check that out before you try and say I have no proof. If you think your numbers are legit MD numbers than your 232/234 cam only LS6 makes 20 rwhp less than robz's car does on a MD and he has been 138mph in the 1/4.
