Car Sits Lower On Passenger Side
Old 11-15-2008, 08:14 PM
waiting2bl33d's Avatar
Default Car Sits Lower On Passenger Side
well i've got a friend with a 98 Camaro Z28 with a little over 150,000 i've always had my questions on the car it always sat different atleast compared to mine. well i meased it from the ground to the wheel well and the passenger side sits an inch lower from and rear compared to the driver side. it has OEM suspenion almost all around. from what i can tell the car has an Edelbrock Torque arm, UMI rear control arm's. shocks in the rear look factory and the struts up front are factory. just wondering if the coil springs could just be bad over time or what else so we can get this fixed. thanks
Old 11-15-2008, 09:16 PM
ChoiceCam00's Avatar
Default Difference!
From what I know about my 2000 SS, from the factory, GM engineered the driver's side to be 1/2-1inch to make up the weight of the driver. This might not be true but that's what I know.
Old 11-15-2008, 10:10 PM
jsteele90's Avatar
maybe they removed the springs to do the heater hose mod and didnt get them lined back up evenly
Old 11-15-2008, 11:44 PM
ZexGX's Avatar
It's the gangster lean. Many F-bodies do this... Mine does.
Old 11-15-2008, 11:48 PM
UAZ28SS's Avatar
Mine does it too... just a bit, though.
Old 11-16-2008, 08:02 AM
LS1W66's Avatar
They All sit high on the left so it's Normal
Old 11-16-2008, 01:25 PM
keith_AE2010's Avatar
Mine does this. Its very annoying.
So replacing rear springs with stock ones wouldnt help?
I just thought mine got old and saggy
Old 11-16-2008, 03:26 PM
LS199's Avatar
My 99 ta is the same way
Old 11-16-2008, 03:35 PM
Vicinity's Avatar
It's to offset your weight while in the car. Sit in the drivers seat and watch it magically fix itself.
Old 11-16-2008, 07:09 PM
GR8GAME's Avatar
Tell 'em to get a thinner GF and he wouldn't have that problem!
Old 11-18-2008, 08:32 AM
00firehawk's Avatar
The firehawk i have now does that and so did the 94 formula i owned.
Quick Reply: Car Sits Lower On Passenger Side
