MSD Fuel Pump Voltage Booster ... What is it worth?
Check my sig on my engine combo. I am using a twin 255-L/hr fuel pump in-tank setup from LPA. I have a -8 supply and -6 return line with a MagnaFuel regulator. I am looking to upgrade the injectors from 96# to 120# for the switch to E85. I want to know how much fuel volume increase should I expect from using MSD FPVB. The most fuel pressure they will see is about 60psi even under boost.
