Gears & Axles - Wheel Spacers?
greatskiiiier
11-17-2008, 07:23 AM
How many of you would recommend them?
How many of you have em?
How many of you refuse to use em?
- 1 INCH SPACERS
greatskiiiier
11-18-2008, 09:35 AM
42 views and only 1 vote? at least vote on somethin'!
BlackScreaminMachine
11-18-2008, 10:15 AM
In general I try to match the wheel to the proper back spacing, and IF I have to use a space, I make sure the Wheel stud WILL meet NHRA requirements of having so much of the stud extend out from the Lug nut.
Its def going to look goofy when the street rims are on it but thats being safe and getting through tech inspection.
The a spacer like that the stud should be at least that much longer in my opinion.
depends on your intentions with the spacers, and also the type of spacer. lug nut can play a factor too.
for street wheels/tires, you are probably fine in most cases. if you have sticky tires and like to launch, expect a chance to warp or break wheel studs.
a stock typle lugnut is the worst for this, as it doesnt put any force on the spacer itself, and can actually sheer the studs off over time.
a mag type lug nut firmly holds against the spacer, so there would be less chance of a failure.
onto the spacer. never buy the universal spacers. buy a billet machined spacer for your lug stud and your lug pattern if at all possible.
greatskiiiier
11-19-2008, 08:05 AM
http://riggedup.ecrater.com/product.php?pid=892568
found these... good price but are 2in spacers strong enough?
11-19-2008, 10:46 AM
I wouldnt never trust it on a Stock or even Moser Stud.
greatskiiiier
11-19-2008, 02:55 PM
I wouldnt never trust it.
double negative= I would trust it???
11-21-2008, 06:17 AM
How about this.
Don't Do it.
the_merv
11-21-2008, 07:46 AM
I wouldn't trust the Aluminum ones..
A friend of mine is running Steel ones for a car he has..has no problems with them.
Big Bird WS6
11-21-2008, 08:02 AM
guys you relies that is made out of 6061 aluminum. that has a tensel streght greater then chromoly.
now it would be made out of 2024. that would be even stronger. but i WOULDtrust them
greatskiiiier
11-21-2008, 08:47 AM
hm, trust the guys with no experience, or the one who uses big fancy numbers hahaha... i personally dont believe in aluminum (for its strength is common places), but my blocks made out of it so how bad can it be! hahaha
sn8ke eatr
11-22-2008, 01:08 PM
http://i423.photobucket.com/albums/pp318/Bosshogg803/CongratsGayThreadKnightRiderGaryCol.jpg
greatskiiiier
11-22-2008, 04:32 PM
i thought you could only put mods in your sig that are on your car.. i could be mistaken
SoxXpupPeT
12-28-2008, 08:34 PM
make sure the back side fits the hub on the axle and that the front has the same hub for the rim to be centered on. my boss is making spacers for his vette. if not youll have issues
19mike84
12-28-2008, 10:05 PM
gosh you can fit 11 in wide wheels by just cutting off the bump stops, if even needing that.... how much more do you need?
S_carve
12-28-2008, 10:10 PM
I used the aluminum style ones on a jeep i had, 1.5" per side with 33" tires. Never had a issue when I was wheeling, but then again it didnt have 300+ hp.
oh yeah the guy said it was a gay thread, he has a pic of David Hasselhoff and Gary Coleman on his computer, whats more gay?
ajrothm
12-28-2008, 10:46 PM
I use the billet 1/2" spacers that are lug centric from Thunder racing. I also use long ARP studs....no problems, no vibrations at any speed(at least up to 100). I have put about 5k miles on this setup to get my Z06 replica wheels to fit right on a T/A. Making around 550hp and running on Nitto Drs.
kc533
12-29-2008, 08:24 PM
I had previously ran these 2.5" thick bad boys (see pic below) on my Blazer in order to fit some C5 'Vette wheels. Never had a problem w/ them, however I never did any kind of racing w/ that setup.
As previously stated, make sure you purchase spacers that are at least hub-centric, it'll drastically reduce the chance of vibration.
http://img152.imageshack.us/img152/4663/dsc06522id6.jpg
Big Bird WS6
12-29-2008, 09:29 PM
what this mean?
Big Bird WS6
12-29-2008, 09:32 PM
ok first your block is made out of it so must be good.
second your right i have no experience. but if i can make a set of alumium LCA that run low 9s. i dont worry about my "wheel spacer" experience.
alumium is good. great? IDK. it all depends what you want. the guy a few post up said he has a friend that uses steel ones. well those are probly good. have wieght but good. now the alum are fine. it makes a big difference as long as you have them tight.
9000th01ss
01-25-2009, 09:50 AM
I might be able to get a pic of a truck in the junkyard with 2" aluminum spacers. It was hit on the pass front wheel, the wheel broke off, upper control arm broke off, spindle broke.
The center of the wheel is still held on strong by the spacer.
dschmittie1
01-25-2009, 07:23 PM
I plan on using a 2" spacer so I can run my stock wheels with my narrowed rear for some street cruising and then my dished drag wheels at the track
3fourty6
01-27-2009, 08:01 PM
That's also my plan. I will probly be too lazy to change from the drag setup and just cruise on them also :bang:
