Looking for a C100 Connector
Old 11-18-2008, 12:26 AM
bowtiekid's Avatar
Default Looking for a C100 Connector
Where can I find a a C100 Connector ( Big connector on passenger side fender ) it has the wires for the fans and other things...
Mine broke during the !wire mod.. How lame
Just curious if anyone knows where to get this conenctor.
Thanks
-mark
Old 11-18-2008, 12:36 AM
the_merv's Avatar
Junk Yard bro, that will be a common piece. Then you will just have to re-pin it.
Old 11-18-2008, 12:49 AM
bowtiekid's Avatar
Only junkyard aorund me has 2 camaros, and they're v6's....
Does it matter?
-mark
Old 11-18-2008, 12:54 AM
the_merv's Avatar
They should have them on the Wheel Well.
Old 11-18-2008, 12:55 AM
bowtiekid's Avatar
But it doesnt matter if its a v6 or lt correct?
If not then ya I can get one.
What terminals do they use inside?
Old 11-18-2008, 01:07 AM
TwoFast4Lv's Avatar
Just find one and pin your wires into it. No need to cut them
Old 11-18-2008, 01:09 AM
the_merv's Avatar
V6's have the same. What do you mean by what Terminals?
You mean which Wires are used?
They are called Pins, and to replace that the correct way would be to take the Wires out of the broken Connector and put them in the new Connector the exact spot they were in.
An alternate way would be to use some Butt Connectors and cut it off and put it back together the way the Wires were, keep them lined up in the same spot.
Old 11-18-2008, 01:11 AM
the_merv's Avatar
Some people may not know how to get them apart. I've been looking for the little Tool that does that, I've seen one before and have never found one again. I have been stuck using a small Paper Clip.
Old 11-18-2008, 01:19 AM
bowtiekid's Avatar
I mean terminals as in the actual piece thats going to make contact with the body side.
My harness isnt long enough to my liking. So I would get the new c100 from the yard, pin in with new pins, then just pig tail and solder wires one by one according to the old one.
Old 11-18-2008, 01:29 AM
bowtiekid's Avatar
a sponsor on this site has them
heres the link:
http://www.lsxtune.com/shop/index.php/cPath/111_113
Quick Reply: Looking for a C100 Connector
