LT1s and Fans? WTF !!!
This is the second LT1 Camaro I got with the same exact problem. Fans do NOT come on. The first one was a 94Z and no one could find what was wrong with it, I went through many relays and different computer but couldn't find the problem and had to install a manual switch to turn them on. A friend of mine went through the SAME EXACT thing and couldn't find anything, in his case believe it or not even the dealership gave up on it.
Now I bought a different project and guess what, fans do not come on. I couldn't solve it few years ago and I'm begging you guys to help me out.
What would be the list of things to check/replace to FIX this. What's on top of your list and what's the last thing you think causing the issue.
Thanks a lot.
Thanks a lot.
Ok, I'll do that but coolant temp. sensor on the block? what is that? I know that the gauge temp. sensor is on the head, the coolant temp. sensor is on the water pump, but what's that one on the block? On driver side? Is it in anyway related to turning the fans on. Thanks
Anyway, I just want to solve this problem because it seems to me that the issue isn't just replacing a sensor/relay (I don't think I'm that lucky BECAUSE I'VE BEEN THERE BEFORE WITH A DIFFERENT ONE) but there's something deeper than that. Someone out there must know the problem for this thing. I'm just trying to come up with a list of things and go through 1 by 1 to find out what it is because a lot of people had the same issue.
Nah, that one goes bad very often I agree and the only thing it does is throw that stupid red "Low Coolant" light right in the middle of your cluster.
Well, the temp. sensor on the water pump sends info to the computer to send info to the relay to turn the fans on, something in this route is not right but I couldn't figure what it is when working on my older LT1 car EVEN BY REPLACING ALL THESE PARTS fans still won't come on. Someone must have gone through this and solved it out there.
1- Computer is ok.
2- Fans do work PHYSICALLY.
3- Replaced relay anyway because THERE'S NO WAY TO TEST IT.
4- Wires back to fuse are perfect.
Does it make any sense that with all these being ok and fans still don't come on? If so, there must be something else that I'm trying to find.
Not trying to be a smart *** or hard, but I did ALL OF THE ABOVE with my 94 and could not find a thing wrong, I ended up as mentioned before running a manual switch.
Thanks for your response man.
Oh well, I myself have a 96 SS (Not the car with the problem) and I tuned the computer to have the fans come on at a much lower temp than stupid GM computers do. I don't know why you didn't do anything yet because ur hurting ur engine there man. Who wants to have his engine run hot!! spend 70 bucks and get yourself the slp fan switch.
My car doesn't get much past the first tic in normal day to day driving.
Bingo. BUT, let's say I did all this and found :
1- Computer is ok.
3- Replaced relay anyway because THERE NO WAY TO TEST IT.
1- Computer is ok.
Good question. Answer : THEY DO NOT COME ON AT ALL. (Read the last 3 words in first line and first 2 words in second line of my post on top). What does that mean? Red line and not on yet. More? Antifreeze start boiling in rad. and STILL not coming on .
Let's keep the subject on the fans guys , It's project engine so I don't mind having it get to the red line, but WTF is up with the fans?
I didn't overheat. I have no need to fix this yet as it isn't a problem. The only reason I had this happen is because I idled in place with the AC on max for 20 minutes to see when/if they were going to come on.
But hey if ur happy with it and don't want to miss with wires and stuff, then ur good.
You're in good shape then, I'd STILL install a manual switch to run them way earlier than factory, not only it helps performance but your engine will live longer. It's a fact.
Try wiggling the relay box under the hood. My a/c compressor doesnt come on sometimes and i have to wiggle the relay box to make it come on. Something isnt making a connection and i am too lazy to fix it b/c it is summer.
Thats something simple. Also just trace all of the wires and make sure something isnt grounded or burned out. Im betting that is the problem. If the fans work, the relays work, and the pcm is good, then it has to be something in between.
Or like said above the pcm may not know the temperature of the engine so you may need to change a sensor.
I like to start with free stuff first though.
Good points, thanks a lot man, I'll do that Thursday and let yaknow if I find something. It's just very frustrating to have the same issue twice with two different LT1s.
How about you just tell us what the temperature is at. Are they both on after 235F? If not, THEN yes there is a problem. If you're not waiting till 225f and 235f, then you're jumping the gun. And yes I realize this is your second LT1, but look how many people buy imports over and over, or Mustangs over and over, and are STILL RETARDS
Might want to work on the RIF skills before you call _other_ people retards...
