Expected gain w/ catback & headers?
I'm thinking about getting Pacesetter uncoated long tube headers/Y pipe with a Texas Speed catback. I tried searching, but couldn't find any sort of gains for this listed.
I'm a little tight on cash right now though, so I was also wondering if it would be worth it do just the catback alone and get the headers/Y when I can better afford it.
A third possibility is cutting off the exhaust under my car until I can afford it all at once. Has anyone done this? My friends have done this on their old Mustangs and they sounded awesome, but is there any other benefit to it?
Agreed, you will not get nearly the gain unless they are ceramic coated. Not enough to make it worth the effort at least. As for power, id expect around 30 horse with full exhaust. give or take some. . .
You can expect a gain of around 20+hp at the tire, get a tune also.
The coated ones look nicer and cool off faster but I don't think theres any noticable difference power wise. I got coated pacesetters just because I had uncoated ones previously and they looked gross after a bit.
yeah im with everyone else, probably around 30-35 hp depending if you got a factory freak if ur lucky. I also think you should get the ceramic coated headers to keep down the heat and they look a million times better. I got a buddy that has the painted ones and the paint came off pretty much and they look not so bueno anymore. If you dont get the ceramics then at least get them coated. good luck and post up vids after you put it all on so we can hear it.
I saw a before and after dyno, stock manifolds, stock CB to LT's, 2.5 inch TD's. 38rwhp, 22rwtq gain. But he also got a tune, well at least i think.
You can expect anywhere from 25-35rwhp with LT's, 3 inch CB, pcm tune.
