Single Digit Club - Anyone have an LS7 running single digits? (Curious)
fasttagurl
11-19-2008, 03:48 PM
If anyone knows ANYONE that has an LS7 (427-454) block running single digits either all motor or with a turbo, please post about them/post up! I am interested in your combo since I know nothing except the LS1. I know the LS7 is similar to the C5R, and half the cost. Thanks for the responses!
check out my 9.9 all motor combo at http://forums.corvetteforum.com/1565494941-post32.html
fasttagurl
11-20-2008, 07:56 AM
Getting a database error = I will keep trying. Thx.
ndfrsd6
11-20-2008, 09:58 AM
your running mid 10's now on a stock cube car.....you will be in the 9's for sure if you go with a bigger cube motor ! even if you go with a 402 - 416 you'll easily be there .. i ran mid 10's @ 130 mph with a 402 m6 and am coverting to a th400 and a 5000+ stall ,and have taken a 100 more pounds off of my 3000lb car so im looking for 9's
if you did go bigger cubes regardless you should be there :)
magnum-gto
11-20-2008, 12:51 PM
Yes....we're running a 427 LS7. No FI but we're spraying 200.
Race weight for the GTO is about 3750.
tektrans
11-21-2008, 06:34 AM
N/a 441 LS7 block with L92 heads here.
times in the sig.
2002_z28_m6
12-13-2008, 10:26 AM
A local guy has a ls7 powered 02 camaro that runs in the high 9's. Until he put it on the
bumper and broke a bunch of stuff.
snipers
12-30-2008, 05:19 PM
our C4 LS7 N/A 9.6sec footbrake.
I will post some pic and vid soon:D
Bad ZO6
01-12-2009, 10:12 PM
I'm running consistent 9.9's with my C6 ZO6 (LS7 motor)
My car is supercharged and has cam/heads and Auto Tranny conversion..
http://i130.photobucket.com/albums/p266/jwgaddis68/zo6%20pics/9s.jpg
Here's a vid on youtube
http://www.youtube.com/watch?v=lE6Uxo418AI
Pic of my car
http://i130.photobucket.com/albums/p266/jwgaddis68/zo6%20pics/18.jpg
chummmma
02-28-2009, 04:58 PM
we just went 8.81 on a ls7 block with a blower in a c6z06
SlickVert
02-28-2009, 06:52 PM
That's moving in a C6!
Let's see the vid, I bet the MPH is in the 160's
Bob
chummmma
02-28-2009, 08:50 PM
Bob
155 its a 4l80e car :) video will get uploaded when we get back to shop from baton rouge.
Master8ter
03-01-2009, 10:44 AM
A buddy on mine here in New Orleans has a C6Z06 with a build motor and a procharger running 11psi. Hes got 730rwhp (830crank) with a street tune. This car is his DD.
I've never seen him run at the track, but I'm sure it has 9sec potential with that kind of power.
PUNISHER TA
03-01-2009, 07:59 PM
Im just starting my build 454 LSX. Daily Driver. Full Weight. Hope to be in the 9's. with a little juice if necessary.
atomicfusion
03-03-2009, 08:51 AM
There are a bunch of guys running 9's with LSX's and LS7's and 1 guy (for now) running 8's.
My car runs consistant 9.20's with APS Twin Turbos and a LSX block.
In a F'body you should be in the 9's easily with all motor if it is built right.
Domsz06
03-29-2009, 02:12 PM
Pic of my car
who did your auto tranny conversion? Are you running the 4L60E?
Thanks I'm looking at doing the same/similar thing it looks like your doing.
azooooz
04-06-2009, 07:19 PM
TNTADDICT (member here) runs 9.3 with his N/A ls7 without trans brake
Ryan@RPM-Motorsports
04-07-2009, 06:24 AM
8.16 @ 170
LS7 block with c5r heads. This is with N20
N/A LS7 427 in C5. Check out the video here http://lsx.streetfire.net/video/a3a79ce0-c11d-426c-971f-9b9501274ffc.htm
xfactor_pitbulls
05-05-2009, 02:41 PM
Who cares what block its based on. A 416/418 off an L92 block would be even cheaper and still make killer power.
