Will 295/45/17 Fit on a 01 firebird?
Old 11-20-2008, 11:12 AM
94lt1m6's Avatar
Default Will 295/45/17 Fit on a 01 firebird?
Im not asking if the Tire will fit on the wheel, But will the sidewall, and Width clear everything?
This is a rear tire.
Old 11-20-2008, 12:23 PM
Customizing Director
MadIceV8's Avatar
Depends if the car is lowered or not. But it should fit fine. Your MPH will be a different story though.
Old 11-20-2008, 12:29 PM
94lt1m6's Avatar
Right now it's not lowered, but I had thought about doing that in the future. Do you think a 1" drop would rub?
My speedo is wrong already.
Old 11-20-2008, 02:16 PM
KH504's Avatar
Default 325/45/17 m&h
Its not the same tire but I put 325/45/17 M&H on 10.5 TTM and fit with no problems. stock springs
Old 11-20-2008, 09:07 PM
94lt1m6's Avatar
If that fit, im sure these will no sweat, that tire is much taller. Do you guys think the tall sidewall will look dumb?
I am debating on getting mickey thompson ET II's which would be wider, and a little taller, or the ET I's which would be skinnier but Are a proven tire. They seem to be close to the same from what MT's website says, just diffrent size options. Do you guys know any info comparing the two in a performance aspect?
Old 11-22-2008, 10:55 AM
DopdBrd's Avatar
I think both the tires are the same compound. The only difference is the ET II was made in more low pro sizes, like the 315/30R18, 315/35R17, and such.
I'm no expert, but I think they designed the ET Street Radial as more of a "race" tire with minimal grooves and more of a slick look. The ET Street Radial II was designed with more grooves to expell water and designed for more "street friendly" applications. But like I said they are both made of the same compound.
Quick Reply: Will 295/45/17 Fit on a 01 firebird?
