DD Strange or AFCO Shocks
Old 11-20-2008, 11:24 AM
00cls1camaross's Avatar
Default DD Strange or AFCO Shocks
Does Anyone DD a Strange or AFCO coilover? I think i am going to have a Double Adjustable to help me adjust for street use and then be able to adjust it for track use.
Old 11-20-2008, 02:23 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
We have several employees and customers that use the strange shocks on their cars and they do drive them some on a daily basis others two or more times a week. Both afco and strange are capable of handling the daily grind of everyday use.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-20-2008, 03:20 PM
YellowToy/A's Avatar
You can use them but they are more of a drag shock. Car will not handle well but they launch well. If you want good 60ft times and not great handling for it.
Old 11-20-2008, 03:28 PM
do you have any experience with these?
Old 11-21-2008, 07:55 AM
mad_steve's Avatar
We offer the D/A AFCO shocks. We have a good amount of customers that use these shocks on the street, and so far, we haven't heard any complaints. If you order these shocks from us, we'll give you a base setting on your shocks for street and track use, and if you run into any problems, we'll be able to give you tech advise and shock changes over the phone when you're at the track. If you're interested, please call me at our shop during normal business hour. 8am-5pm Mon-Fri. Phone number is 225-673-3533. Thanks
Old 11-21-2008, 08:01 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
My LT1 car has AFCO coil overs, Madman torque arm, Wolfe Rear Swaybar & PA Racing k-member.
I drove it quite a bit on the street with double adjustable AFCO's. Had a 60mi round trip to/from work. They have a wide range of adjustability & can be set pretty firm to somewhat offset a soft drag front spring.
I left the rears at the same race settings, but just tightened the front extension a few numbers on the street to keep the front end down & help the cornering. I would almost forget about the race suspension until making a sharp turn into a steep driveway would lift the inside rear wheel off the ground from the stiff Wolfe Swaybar.
Call Madman, he can get you a good setup.
Old 11-22-2008, 08:44 AM
studderin's Avatar
I've put like 10K on my stange single drag shocks. I tighten them up to 4-5 on the street
Quick Reply: DD Strange or AFCO Shocks
