3.73 to 3.42s -- big difference?
Old 09-22-2003, 06:41 AM
UGOT8's Avatar
Default 3.73 to 3.42s -- big difference?
I have a motive performance 3.73 .. and I think the cut on the gear is bad because at high speeds there is a TERRIBLE vibration .. so bad it broke my tailshaft in half at 120mph.
i was told that the most likely cause of the vibration would be the gear .. so i'm going to start troubleshooting.
my friend has a gm 3.42 gear that i thought about switching to ..
will there be a big difference in my ET? i do want more top speed than 110 .. and with this setup i have now i'm afraid to hit 100 because i don't want to kill anything else.
TIA
::Austin::
Old 09-22-2003, 11:01 AM
Colonel's Avatar
Default Re: 3.73 to 3.42s -- big difference?
Your ETs will hardly know the difference...especially if you have a good TQ converter.
Old 09-24-2003, 08:09 PM
UGOT8's Avatar
So what do you think is causing the vibration? The cut on the gear? All bearings and everything were replaced when I had the gear put in .. and the guy who did it has an excellent reputation.
