why is my aeroforce saying i'm lean but.
1 Post
Are you saying that you have richened it almost to the max percentage on the predator and you are still lean on the wideband? You only have so much adjustment using the predator - it might not be enough for your mods... or you have a fuel system issue... either way, hard to diagnose it here without more info
1 Post
No way a stock car should be maxing out the fueling in the predator - I would look at the fuel system for issues... check fuel pressure under WOT for starters. When you say drop in, what do you mean?
LS1Tech Sponsor
Isn't the aeroforce an OBDII guage?
What are you looking at that says you are lean?
You need a wideband to see A/F ratio.
My guess is you are not running lean at all, probably super rich if you have 25% fueling added at WOT....
Do you think it is saying you are lean at WOT or just at cruise?
Lean at WOT I had a friend with me yesterday afternoon and he said it smelt like it's lean and my aeroforce also says it's lean. I have the aeroforce set to my long term fuel trims.
