10 Bolt Rebuild Kit?
Old 11-21-2008, 02:00 AM
Vicinity's Avatar
Default 10 Bolt Rebuild Kit?
Anywhere I can find a kit with all the bearings, spider gears and other replaceables for the stocker rear end?
Old 11-21-2008, 04:11 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1009
Here is the rebuild kit, but does not include spider gears. Bob
Old 11-22-2008, 03:27 PM
Vicinity's Avatar
Any idea where I can get a new set of spider gears?
Old 11-22-2008, 10:14 PM
Vicinity's Avatar
Sorry to the mods admins, but I've been looking for a month and this is the only place I've found that sells Spider gears...
http://www.ringpinion.com/ProductDet...px?ProdID=1175
Are these the correct gears for the 10bolt in the Fbod?
Old 11-24-2008, 07:03 AM
Vicinity's Avatar
Bump.
I have a feeling it'll be a while til someone answers with even a sarcastic remark... Damn 10 bolt.
Old 11-24-2008, 08:40 AM
camd01silv's Avatar
Those look to be the correct ones, if you are rebuilding a completely stock rear. Unless you get some clutches or saved your old ones, those will only make it an open differential, not a posi or limited slip.
Old 11-24-2008, 06:45 PM
Vicinity's Avatar
It's completely stock. As far as I know, it's never been opens except to change the fluid, so I can use those?
Old 11-25-2008, 06:22 PM
All Black SS's Avatar
OK, what is IT? A V6 car? then those gears might work.
If it has an LS1 theres a good chance it has some sort of limited slip. Those gears pictured are not for any type of limited slip.
Old 11-25-2008, 06:52 PM
03 BUSA's Avatar
I don't think anyone will care about losing the business on a 10 bolt rebuild. Atleast when it blows up again they can't be held responsible. J/K
Old 10-28-2009, 02:20 PM
CamaroSS01SLP's Avatar
Would this kit completely refreshen my 10-bolt to where it gets back to specs?......The reason I ask is because I have some "play" or "slack" if you will when accelerating......It seems as if there is a delay when I give it gas & it's not my torque arm bushing, it's not my tranny mount or motor mounts as I had them inspected. The tech told me that the backlash of my vehicles rear is too much & I just need to rebuild it. Anythign else besides whats included in the kit that I'd need?.......
Old 10-28-2009, 04:23 PM
Spartan7's Avatar
Why are you looking for spider gears? They are not a normally replaced part of a posi. I went with a Ratech deluxe kit. It comes with all bearings, seals, and shims needed for a complete rebuild. I would get a Fel-pro diff gasket though, the cork one that comes with the kit is crap.
The next thing you need is a rear end guru that knows what he is doing. The kit won't do any good if the install sucks.
Quick Reply: 10 Bolt Rebuild Kit?
